Question about Lenovo TOPSELLER THINKPAD X201 I5540MSYST253G 320GB 4GB DVDR 121WXGA W7P (32492VU) PC Notebook
Getting bootguard message and black screen when i power up my lenovo thinkpad laptop
kamal1984
  • 1383 Answers
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Posted on Jul 29, 2009
shynysaxena
  • 166 Answers
SOURCE: Lenovo ThinkPad and a blue screen
Sir this is due to Hard disk internal problems and you will need to perform PRIMARY HDD test by using BIOS setup wizard.
Posted on Jul 21, 2009
  • 41 Answers
SOURCE: Lenovo SL500 Thinkpad
1. Take off the the power plug
2. take off the battery
3. press and hold the power button for 10-15 seconds
Now try turning it on, if it still doesn't work, check in your manual how to RAM cover, and take the RAMs out (before you do this repeat stpes 1-3). After the ram is out, try turning it on if you hear sirens , that could be at least some indication that your motherboard is alive. if no sirens --- than you got bad news.
So at least you will now if there is a chance if the motherboard is not dead.
Posted on Jul 28, 2009
  • 165 Answers
SOURCE: lenovo R51e, when power on show error code 271
You need to reset the time in BIOS. The manual for your computer also states that. This manual is available at the following link:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2462_01.pdf
Refer to Page #16 for this error message.
You can get into the BIOS by pressing the F1 or F12 key when the comptuer is starting up. Please note that some changes in BIOS may render the computer in a non bootable state.
On this BIOS screen, set the correct time and date and this should resolve the issue that you are facing.
Posted on Aug 10, 2009
SOURCE: Lenovo ThinkPad R61 Fan
Were you able to fix it? I took out the fan and cleaned it with a toothbrush (didn't disassemble it). If it worked, can you provide some insight into what you did?
Posted on Mar 12, 2010
W701 ds black screen
It should work without a battery just a good power supply plugged in.
Jan 09, 2016 | IBM Lenovo ThinkPad W701ds 25003CU...
Why is my x201 lenovo thinkpad screen black. I am using an external monitor ok.
That means the connecting bus(cable) from the motherboard to the screen is damaged you can check it by opening slowly the screen of ur thinkpad if display comes at some place then the bus is damaged either replace that bus or the screen might be faulty you have to get replaced your thinkpad screen in this case
Jul 23, 2014 | IBM Lenovo ThinkPad X201 Notebook
Lenovo ibm thinkpad cuts off when entering welcome screen
Can you enter safe mode? Do you have option or does it not stay powered long enough?
Nov 03, 2012 | IBM Lenovo ThinkPad X40 Notebook
I'm having a Lenovo T61 Thinkpad. All of a sudden my laptop keeps turning black. I keep getting the error message that display driver stopped working but recovered successfully but this may not always be...
Hi. I think you have uninstall your display driver and download the updated drivers on the Lenovo driver support website.
Go to this website and download the video driver for your laptop: http://www-307.ibm.com/pc/support/site.wss/product.do?doctypeind=9&template=/productselection/landingpages/downloadsDriversLandingPage.vm&sitestyle=lenovo
just make sure that you choose the correct or corresponding operating system that you have on your laptop (e.g XP, VISTA or Windows 7)
After downloading the video driver install it on your laptop then restart you computer. Goodluck!
Jun 13, 2010 | Lenovo ThinkPad T61 Notebook
My lenovo t60 screen goes black 15 seconds after
Hi, try to boot into safemode, turn your system on then keep on tapping F8 to get the windows advance Menu screen, select safemode.
In the safemode windows go to Control panel and check your power options, you will see what time frame your system has for the LCD when turning off.
If this does not fix the issue, try booting into safemode with networking for you to be able to go online in safemode try updating your BIOS from your Manufacturers Website, Updating your bios may fix the issue.
Mar 12, 2010 | Lenovo Thinkpad T60 Notebook
Ibm t61 turns on but all I get is a blank black screen.
This sounds rather bad. You're not even getting a "thinkpad" screen?
Try unplugging the power and removing the battery for a minute and attempt to power up again.
If it's still not starting, try removing the memory modules (if there are two, remove one and try powering up, then try to remove the other one). Although I seem to remember that newer thinkpads will still show thinkpad logo and attempt to POST even with bad memory (then throw an error), it's always worth a try.
If the above don't make any difference then I'm afraid most probably your motherboard has failed. In theory you could also try swapping the cpu-I've seen a cpu go bad ONCE in my several years of tinkering with laptops.
T61 is a current model-wouldn't it still be under warranty from lenovo? Might be worth checking the serial on their website. Otherwise it's time to search for T61 donor laptops on ebay - ordering a new motherboard from lenovo parts suppliers will most probably be far too expensive.
Good luck, hope you get it working again!
Raf
Nov 09, 2009 | Lenovo ThinkPad T61 Notebook
Lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
Dec 14, 2008 | Lenovo Thinkpad T60 Notebook
Lenovo TOPSELLER THINKPAD X201 I5540MSYST253G 320GB 4GB DVDR 121WXGA W7P (32492VU) PC Notebook Logo
4,756 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
