Question about Acme 5001 Supreme Juicerator Juice Extractor
Cleaning after juicing - Acme 5001 Supreme Juicerator Juice Extractor
    Champion:
  • 356 Answers
It's easy. Scoop out the pulp with your hand and
then under running warm water sponge the outside
first and mop up the inside next. Keep rotating the
basket as you clean. If the juicer becomes discolored
after a while, boil the parts in a solution of Oxi Clean
and water, then scrub. She will look like new.
Posted on Jan 30, 2011
Manual for Emson Juice Extractor, Model GH-2011
I bought one without a manual today for 2 dollars at a yard sale , blades lock in about a half inch - turn counter clockwise to remove, may need to press down or press button in back. base below comes off too for cleaning - turn clockwise. They may come off hard the first time. the button in the back may help releasing both. Make sure to unplug first. I don't have a manual either, just some mechanical sense.
Oct 07, 2014 | Juicers
Santos juicer
Couple of things to look at
1 check the grating blade. Maybe clogged therefore need cleaning or need replacing due to bluntness
2 motor may be slipping true to overload. Place fruit in a little at a time
hope this helps
Apr 16, 2014 | Juicers
WelBilt juice extractor JE 200 owners manual
Thank you, thank you, THANK YOU! I turned my Welbilt JE200 upside down & it easily came apart. Also, for the tiny spaces, never underestimate the power of the 3 best cleaning tools: bamboo skewers, Q-tips & an old toothbrush.
Nov 26, 2012 | Juicers
How do you take the juicer apart for cleaning?
Undo the latch arms, remove the cover then the clutch nut in the center of the
blade. Everything should lift out.
Apr 03, 2011 | Omega 1000 Juice Extractor
Ican not remove the the basket for cleaning is to hard
You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Feb 16, 2011 | Salton JM411 Juiceman II Elite Juicer
Filters
Do without them. They lessen the yield and cleaning
the juicer is not that difficult.
Feb 28, 2010 | Acme 5001 Supreme Juicerator Juice...
How does it come apart for cleaning
The hot water did work for mine. Here is the solution I discovered:
After removing the food plunger and juicer cover: (1) Unscrew the 3 screws that hold the cutting blade plate in the center of the basket and lift off the cutting blade plate; (2) Unscrew the base counterclockwise (it will unscrew from the threaded center piece) and lift it up; (3) Lift off the basket and juice bowl. Now you can clean the basket and juice bowl.
To reassemble, reverse the process.
Sep 20, 2009 | Juicers
Cleaning
http://www.smallappliance.com/product.asp?pid=9879&cur=USD&sid=18956&mid=34&gid=18975&prdCls=P&shopBy=Category
Jul 12, 2008 | Acme 5001 Supreme Juicerator Juice...
Juice extractor - dismantling after use
Look at the dismantling and cleaning procedure in JE95XL Juice Fountain Plus user manual on Page 14 and 15. Procedure is the same with JE900.
http://www.breville.ca/site/EN/products/je95xl/je95xl_manual.pdf
This is what manual doesn't tell you: clean the 3 spring loaded pins on the side of the motor clutch. Sugar and pulp may get inside and seize them when dries up, thus making very hard to separate the basket/cutter from the clutch.
Apr 01, 2008 | Juicers
Acme 5001 Supreme Juicerator Juice Extractor Logo
118 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Are you an Acme Juicer Expert? Answer questions, earn points and help others
