Question about Samsung LN-S4692D 46 in. LCD HDTV
Hi, my Samsung LCD TV has been having issues for awhile when it's turning on, it would sometimes take about 5 to 10 minutes to turn on. Its turning on time has consistanly increased and now will not turn on. It keeps making the clicking sound as if it's going to turn on but its not turning on. Can you please help me in trouble shooting this problem. Thank you.
  • Samsung Master
  • 8,457 Answers
U have basic electronic skills?Have all the tools?Take the tv aparts,the board where the power a/c plug into it.That the power supply board,check for these parts call capacitors,it dying about to fail,that why it take power longtime to come on.These capacitors parts on the power supply board are alway bulges up on it tops or puffing up on it tops.This capacitors are dying and leaking.Replaced these capacitors,will solved ur delaying power up tv problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Oct 02, 2010
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
My Samsung HL-T5075S TV shuts off after being on for awhile and will not turn back on,also if you turn it off you have to wait awhile before turning it back on, I have tried unplugging it for up to one...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help.
Sep 15, 2011 | Samsung Televison & Video
My 40 inch LCD sanding tv won't turn on for awhile. It keeps doing the clicking sound for about two minutes before it catches and turns on. Shat should I do?
> Shat should I do?
Take it to a qualified TV/video technician, for proper trouble-shooting and repair, because this problem has no "end-user" repairable parts.
Oct 23, 2010 | Samsung SM400P 40" LCD Monitor
When i turn on the tv it makes a clicking noise while it tries to turn on . it takes awhile for the tv to turn on. i'm assuming the clicking noise is the tv trying to turn on but cant. it eventually turns...
The clicking is the power on relay. The problem may be with the power supply or the load (one of the circuit boards). If its out of warranty. Open up the back and look at the power supply board. Look for swollen caps and other overheated parts. Do it with the power cord unplugged. You will probably have to have a service visit....
Apr 16, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
TV turns off and on
you have bad electrolytic caps in the power supply---remove power supply replace swollen caps--if you do not think you can replace caps try shopjimmys.com enter model number scroll down to find power supply-if they do not have in stock write down part number then google it to find one
Sep 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
Samsung lcd tv no picture just sound
While this is not a permanent solution, we've fond it helps... We have a Samsung LCD that does not turn on when there is too much humidity in the room. This only happens in the summer when it gets really humid. We moved our dehumidifier next to it, let it run for around 15 minutes and the TV turned on again, no problem. Lately, it's been raining alot so it's very humid. We've gotten into the habit of leaving our dehumidifier on through the night on low and we've had not issues turning on the tv since then. This is a hastle but it's either that or buying a new tv.
May 26, 2008 | Televison & Video
Samsung LN-S4692D 46 in. LCD HDTV Logo
206 people viewed this question
Henry  Thomas
Henry Thomas
