Question about Samsung Heating & Cooling
After the code numbers in samsung AQv18fan , the unit is ok , but all LEDs , in the power on of unit is OFF .!!
When I turn on the air con. after 30 min. about it stops working, and the red turbo button get lights. End now it works but not heating, just working?
Posted on Nov 21, 2010
I have a HL67A750 Samsung no picture no sound blue light luminated on front 3 LEDs flashing
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 05, 2017 | Samsung Televison & Video
Tip
How to trouble shoot no display problem in PC
Mostly the prolem comes with PCs is no display. When such situation comes we can try following DIY and 90% the faulty part could be diagnosed:
1.Unplug the VGA cable of the monutor and if monitor shows some message (check signal cable) monitor is ok
2.First check for the power whether LEDs are blinking?If yes power unit is fine.
3.Check for the responses of the kwyboard LEDs, if after switching on LEDs are blinking processor is ok otherwise there is some issue with Processor.(Note it might not blink if the mainboard is burned)
4.Try to press num lock key if the LED is responding most probably this is the issue with RAM otherwise with Mainboard.
Thanks
on Dec 08, 2009 | Computers & Internet
I have a Mitsubishi Split model MSH-09NV but not turn on, and the leds are off. The Split not work with bottom emergency neither.
Ensure power supply is correct and you have correct live and neutral and Earth at unit, test power across live and neutral to see voltage at outdoor unit terminals
Dec 04, 2015 | Mitsubishi Heating & Cooling
Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Lighter...
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
Jan 28, 2015 | Samsung Televison & Video
POWERS UP W BEEPS BUT NO PICTURE THEN ALL 3 LIGHTS ON FRONT BEGIN TO BLINK STILL NO PICTURE
all 3 leds = lamp failure
if lamp is ok, it can also be the lamp driver, color wheel, or dmd board(rare)
first pull out the lamp and check that, likely your bad part, part numbers on the side of the tv, www.dlplampsource.com for parts.
let me know if I can provide further assistance.
Sep 09, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Unlock my Samsung!!!
enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to
Sep 05, 2009 | Samsung Hue (SCH-r500) Cellular Phone
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Things I have checked on the HLP4663W
Hello Brandon B
Must say you have done more than what most people are willing to do. Great job. You have only one problem. Your lamp need changing. Thats it. This unit carries two type of lamp. Look at the right side of the cabinet for the lamp code
List price $150
Part Number:
BP96-00826A
LAMP 120W( L3 TYPE , VERSION PW03, PL02 UNITS
BP96-00224J
LAMP ASSY (PHILLIP) VERSION 0001 UNITS
Best regards
circuitcity
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Accordianman--Dual deck VCR not responding...
No. Sound like the Switch mode power supply is or has failed, to repair this would involve replacing capacitor and or some componets, Many repair shops these days have discontinude repairing VCR's becuse most of the time you can replace the entire unit for the cost of repairing it
Feb 24, 2008 | Televison & Video
No power
Can you just clarify how much you are certain the adapter is OK......did you you for argument sake try another adapter. The battery might be poked or that adapter not going. I know laptops may get sentimental (so to speak)but they dont just shut down for no reasons technically unless the battery is stuffed or there is NO power to the unit. Thats why the LEDS are not lighting up?
Sep 06, 2007 | Toshiba Satellite A105-S4014 Notebook PC
Heating & Cooling Logo
316 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
