Question about Health & Beauty
Wiring diagram for Pride Gogo - Health & Beauty
gewiz
  • 1263 Answers
SOURCE: PRIDE GOGO ULTRA X Beeps and Cuts off
Please make sure your charger is okay, can you try another charger ?
the other thing is , the FREEWHEEL lever can it move itself say when you go down a kerb , what are they replacing ? do you have the part ? send me a photograph if you do ?
Posted on Jun 13, 2009
SOURCE: I have a Pride Gogo 3 wheel scooter. Suddenly I
the lever at the back may be slack and missing the turn-point. Try moving up and down a few times, very gently, this may get the correct position,.
Posted on Sep 14, 2009
hawk127311
  • 350 Answers
SOURCE: where and how do I replace my battery for my pride
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY!
Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
Posted on Feb 24, 2010
  • 26 Answers
SOURCE: pride gogo ultra electric brake totally broken
try mobilitry centre penge 0208676 0944
Posted on Apr 15, 2010
  • 692 Answers
SOURCE: Wiring diagram gogo scooter
Eric, I have one but I need your e-mail address to send it to you. E-mail me at lennieg2000@yahoo.com and I'll send it
Posted on Aug 22, 2010
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Jul 25, 2014 | Pride Mobility Products GoGo Elite...
Where does one get the wiring diagram
http://www.icare-jmb.com/Documents%20partages/eclates/pride/scooters/BASE-GOGO.pdf
This illustrated parts breakdown will allow you to follow the wiring harnesses and check and test all the interconnects. This manual will allow you to remove covers and locate parts. Some basic problems can be solved by checking for loose, disconnected, burnt or damaged wiring and connectors. This manual will also give you part numbers. It is best to check with customer service before ordering parts since there are parts changes based on Model and serial number.
Just as a point of reference, most issues for this model can be found in the electronics assembly console, the plugs at the controller and the battery box connections and HIDDEN fuses. B7 page 30 is a good example of a hidden fuse on the battery box that is sometimes burnt out. E3 page 28 is another hidden fuse. Hope this helps.
Mar 26, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Wiring diagram on a gogo scooter
The wiring interconnects on these scooter are all modular and the blow up assembly diagrams are all you need to trace the wiring and replace components. Aside from a dealer log in to the manufacturer's website you can go to southwest medical's website and get all the information on the wiring and parts. Hope this helps.
SC40X Go Go Ultra Replacement Parts
Mar 01, 2014 | Pride Mobility Products GoGo Ultra X...
Reset switch
hi , that could be a faulty reset switch, I come back later and give you a more complete reply as i run out of time now.
Regards
GeWiz
Feb 10, 2013 | Pride Mobility Products GoGo Ultra X...
Gogo elite pride scooter horn won't stop
Peggy I've just solved mine as well there was a touching wire on the horn! So try that. You have to take some screws off the front panel
Jan 21, 2012 | Pride Go Go Elite Traveller Plus HD 4...
Where can i buy repair maual for gogo ultrx 3 wheel scooter
GO ON-LINE TYPE IN THE WEB SEARCH PANEL ...GOGO ULTRX 3 WHEEL SCOOTER MANUAL, YOU'LL FIND OUT MORE THAN YOU'LL PROBABLY WANT TO KNOW...
BUT YOU WILL BE ABLE TO EITHER DOWNLOAD THIS MANUAL AND SAVE IT TO YOUR COMPUTER,
OR ATLEAST RETREIVE INFO ON WHO THE MANUFACTURER IS AND INFO OF HOW TO CONTACT AND THEY WILL EMAIL YOU THE DIAGRAMS IF REQUESTED OF WHAT PART NUMBERS ARE FOR YOUR SCOOTER!
HOPE THIS HELPS,
MARTIE
Aug 25, 2011 | Pride Health & Beauty
Jun 10, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
158 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
