Question about Whirlpool Dryers
I have a Whirpool LER6620PQ0 dryer. It runs but does not heat. I just replaced the heating element, and it still is not heating. What else can it be?
    Brigadier General:
  • 4,088 Answers
Make sure that you 220 volts AC across the two slanted slots of the power socket--if zero or near it, one of the twin breakers in the house electrical panel for the dryer may have failed. Try pushing the breaker off, then back on and recheck for voltage at the socket. If now ok, try the dryer again. If not ok, then possibly one of the breakers has failed. Hope this helps!
Posted on Oct 02, 2010
I have a Whirpool Dryer model 3LEN 2000PW1 It runs but does not heat?? Four years old. Could it be the heating element?
Hello there:
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Sep 29, 2010 | Whirlpool Dryers
No heat , drum turns and wont shut off
Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 05, 2010 | Whirlpool LER4634J Electric Dryer
I have a whirpool dryer model ler4634pq. I will not heat. I had the heating element and replaced the theromstats on the element but it still does heat. I had the switch checked. I checked to make sure hose...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 13, 2010 | Whirlpool LER4634PQ Electric Dryer
Whirpool dryer 10 years old is still heating but taking very long to dry clothes. Checked dryer vent and it is clear. Will heating element help?
If your heating element is still heating up the cause lies elsewhere. Filter for dryer both at the base of dryer and filter location . If you are getting heat then airflow is the problem. how is the fan motor in front of heating element
Mar 09, 2010 | Whirlpool LER5636P Electric Dryer
Ler6620pq0 wont heat up
Usually no heat with this unit is the thermal cutoff that is attached to the heating canister. It is a 2 piece kit when you have to change it. The other thing would be the element but check the cut off first.
Feb 28, 2010 | Whirlpool Dryers
Dryer model LER6620PQ0 dryer runs, but will not heat
If drier runs and doesnt heat, it can be one of two things. 1)The over temp. th/stat has activated. Possibly it can be reset. or 2)the actual element is faulty, which would need replacement.
Sep 21, 2009 | Whirlpool Dryers
Open Questions:
Dryers Logo
245 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
