Question about Epson Stylus Photo R300 InkJet Printer
My printer R300 will not print
Unit would not switch off, pulled out mains plug and will not now switch on, checked fuses in plug and on ps board inside unit. Help
  • 54 Answers
This is already a hardware issue if that is the case. You can get some info of your local epson servicer near your area through the epson website, support.epson.com and browse for your printer. If you are having problems the contact epson technical support @ 562-276-1300.
Posted on Jun 12, 2008
Why will my hp officejet 6100 turn on it keeps blowing main fuses from mains plug
Short circuited component/s at it main power regulator board. Your printer needs service. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 17, 2015 | HP Hewlett-Packard - CB863AB1 Officejet...
Its not printing anything, I've had it for a couple years now, I just changed the ink after this happened, thinking it was out or gone bad... I've checked the new ink, making sure no plastic was in the...
Problem with printer main board. Usually, it's caused by short circuit at head. If you have experience in electrical circuit and soldering, check mounted fuse at main board. Check for f1 and f2 fuse. If the fuse is off, replace it. But you must check the head first. Find the reference in aicaxz solution for this condition. There are same condition as your printer, that resolved with this technique. But, if you don't have experience better take to epson service center.
Head cleaning is mechanical process, printing is electrical process.
Oct 20, 2009 | Epson Stylus Photo R300 InkJet Printer
A hager b6 fuse has blown - normally the switch flips off and you push the switch back to on and power is restored - here the switch is limp and wont stay in the on position - i cannot see how you remove...
I have just done this myself and without blowing myself up.
1. Tools needed will be a torch and a philips screwdriver
2. Switch off your mains.
3. Check your mains are off
4. On the fuse itself they are two screws. One above the hager sign and one below. Unscrew these. The top screw keeps the wire in from the mains and bottom screw is to keep fuse screwed to the actual fuse box
5. You should be able to remove your fuse now
6. On your new fuse there will be a white piece at the back. Pull that down
7. When the fuse is removed you will see the wire which is now free and on the bottom a plug which is where your new fuse slots in.
8. Slot your new fuse on the plug and tighten the bottom screw.
9. Put your wire in place on the top of the fuse and tighten the top screw.
10. Switch your new fuse on the "on" position.
11. Put back your cover on your fuse box
12. Switch your mains back on.
WHO NEEDS A MAN! PS ONLY ATTEMPT IF COMPETENT OR GET A QUALIFIED ELECTRICIAN!
Sep 12, 2009 | Electrical Supplies
Help me immediately, please
Actually, the "kit" is a DIMM that plugs into the controller on the right side of the copier (when looking at it from the back of copier) On this model, you need to add 64mb of RAM if you want to add functionality to print and scan, along with the DIMM. Yes, there are 2 different DIMM's for this,....one is Print and one is Print/Scan.
PS: there is a kit to install said items that includes buttons for the controll panel and DIMM, however, the memory is separate (laptop memory or SO DIMM)
Jun 29, 2009 | Ricoh Aficio 1035 Copier
Jose349, asked my epson r300 not turn-on with power button.
Open case, check the on swicth. Check electricity to front panel. Check voltage output form ps to board.
Jun 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Feb 21, 2009 | Epson Stylus Photo R300 InkJet Printer
The Phaser just keeps shutting down...
That really sounds like corrupted software.There are some procedures you can try, but they will require setting up the network on the printer , so print a configuration page before you do this.
First though. shut the printer down, on the back of the machine is 2 D shaped knobs. Line them up to the edge of the printer then remove the main board. Reseat your memory cards and reseat that main board assebembly. Be sure everything is seated.
Then do memory resets
PS NVRAM AND JUST A NVRAM reset.
Under troubleshooting
Enter service diagnostics then l and reset PS NVRAM as follows: 1. From the diagnostics Main Menu use the UP and Down arrow keys to highlight Print Engine Menu and press OK. 2. In the Print Engine Menu, use the UP and Down arrow keys to highlight Function Menu and press OK. 3. In the Function Menu, use the UP and Down arrow keys to highlight Clear PS NVRAM and press OK This will set the values in PS NVRAM back to factory defaults. 4. Power the machine off for 30 seconds then power on.
Apr 22, 2008 | Xerox Phaser 8400 Laser Printer
Epson r300
red light flashing parts inside r at the end help
Feb 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson r300 printer
step1..............switch on
step2............press+hold stop,ink,power buttons untill printer switches self of
step3............switch back on and problems should have gone
Aug 21, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
47 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
