Question about Whirlpool Duet GHW9150P Front Load Washer
Error F 35 I see the fixes for it but where exactly is the air dome and pressure shose located?
    Genius:
  • 1,416 Answers
This error code on a washer machine indicates a keypad short on the washer Control (WRC) board. This is the clock/timer on the operator console. The recommended fix is to replace the WRC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an WRCis not a difficult repair and can be accomplished by the average do-it-yourself offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the WRC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the WRC and the assembly will come out.
NOTE: Most replacement WRC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new WRC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
I hop this information helps you.
thanks for visiting.
Posted on Oct 02, 2010
We are getting an error code of F 35
Hi
Error code F 35 means ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the component detected by the Steamer Electronic Board. Please check whether the pressure hose is fixed firmly, and the air trap is not blocked. Make sure the hose is not plugged. If this doesn't resolve the issue then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch, you would need to replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Kenmore Elite HE5t Washer
Washer shows a code f 35 and sud
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 27, 2010 | Washing Machines
F 35 flashing on washer
Hi
Thanks
Rylee
Sep 21, 2010 | Kenmore Elite 45986 Front Load Washer
I keep getting the F 35 and Suds code on my Kenmore Elite front load washer. How can I fix this?
Hi
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F-35 display on whirlpool washer. What is the problem
Hi
Thanks
Rylee
Sep 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 35 error code
Hi
Error code F 35 means ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the component detected by the Steamer Electronic Board. Please check whether the pressure hose is fixed firmly, and the air trap is not blocked. Make sure the hose is not plugged. If this doesn't resolve the issue then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages, then there is an issue with the water level pressure switch, you would need to replace it. Please post back in case of further assistance. Hope this helps...
Daniel
Aug 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error alarm F 35 is displayed on our Whirlpool Duet washing machine model number WFW9600TW00
Hi
Thanks for using FixYa. Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Washing Machines
Kenmore elite washer - HE 5t front load giving error F 35. will not take soap.
Hi
Thanks
Rylee
Aug 09, 2010 | Kenmore Washing Machines
When trying to run the washer we get a SUD error almost right away. Than after a while of nothing happening a F 35 error pops up.
Hi
Thanks
Rylee
Aug 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 35. When you re-start it, it shows a SUD alarm. Than after a period of time without anything really happening the F 35 error pops up.
Hi
Thanks
Rylee
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
