Question about Panasonic KX-T7633 Corded Phone
ANSWERING MACHINE SET UP
I CANNOT FIND MY PUMPLET THAT HAS THE INSTRUCTIONS AND THE PHONE SERIAL NUMBER IS PQLV30054ZAS AND THERE ARE 4 HAND SETS THANK YOU.
    Scholar:
  • 38 Answers
To connect a standard answering machine to this phone, it needs to be wired to a DHLC port and XDP Mode has to be set to "Off." In addition, the Parallel Ringer feature needs to be set to "On" or your ringing phone won't ever ring the answering machine!
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
How do I set the number of rings until answering machine picks up?
Check the instruction manual or run through the settings. Or Google
Make Model Manual
Each one has a different way to get to that setting.
Nov 24, 2015 | Panasonic KX TG1061 Phone
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
Aug 14, 2011 | Uniden DECT 6.0 Cordless Phone
Our DECT2015 phone only rings 4 times and then stops.How cane I adjust the ringing time of our phone? Thanks Peter
Do you have voicemail or an answering machine? This is usually a sign that another device (fax, answering machine or voicemail service) is set to answer the call after 4 rings. You will need to lengthen to number of rings before the service/device in question picks up. (The method to reset this will depend on the service/device that is picking up.) Another possibility is a call forwarding service that is enabled at 4 rings.
I hope this helps. Please write back with details on the device that could be picking up for details on setting the number of rings. If you have voicemail or call forwarding, check with your telephone service provider to lengthen the number of rings before the service kicks in. (There are too many for me to know all of the providers instructions.)
Apr 16, 2011 | Uniden Lands Phones
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Mar 30, 2011 | Uniden Cordless Phone
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Forgot how to record outgoing message on KX-TGA
KX-TGA 101S is the model number of the hand-set. Can you send me the model number of the answering machine? Also do you have the manual for both hand-set and answering machine? If not I can give you the link to download both manuals for free.
Master FixYa...saailer@att.net
Dec 06, 2009 | Panasonic KX-TGA101S Cordless Handset
Phone diverts to machine after just 3rings
Hi, Here's the instructions to change # of rings. You will see that in instructions below, numer 1 says press w, actually what you press is not a w, it looks like three lines. I will also give you a link for the manual as it has good photos on page 23.
http://safemanuals.com/brand-user-guide-instructions-owner-manual/DORO
Scroll down to the box that says, select model number, then scroll to 830R. You will have to enter the 4 numbers into the page before downloading but it's easy.
Good luck. If this helps you plz rate it 'fixya' for me. Thank you kindly.
Number of Rings
The number of rings before the answering machine answers can be selected between
2, 3, 4, 5 or TOLL SAVER.
1. Press w.
2. Scroll using < </> > until a fl ashes in the display. Press 0.
3. Press 0 repeatedly until the display shows 3/5.
4. Scroll using < </> > to the required setting (2, 3, 4, 5 or TOLL). Press 0 to
confi rm setting and move to the next programming sequence, alternatively.
5. Press w to exit the Menu system.
Jan 23, 2009 | Doro 830R Cordless Phone
I have a discontinued phone and have lost the instruction book and need to figure out why the fax machine is not letting the answering machine pick up.
you have both the fax machine and the answering machine on the same phone line.
The fax machine and the answering machine are set to answer in a certain number of rings.
In your case the fax machine is set to answer the line in less rings than the answering machine. You have to increase the number of rings of your fax so that the answering machine will work.
Aug 06, 2008 | Lands Phones
Adding speed dial nos to uniden waterproof handset
I found the model no, on the Uniden website DSS 7805WP and down loaded the manual.. there were no instructions .. but i showed where the phone book icon was .. and once inside the phone book the process was the same as the handset that came with the answering machine.
Jun 19, 2008 | Uniden Tru-Digital Expansion Waterproof...
Changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Feb 14, 2008 | Uniden Cordless Phone
Panasonic KX-T7633 Corded Phone Logo
300 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
