Question about Cameras
Hi I purchased a 4GB SD HC memory card for my samsung digimax s500 but when i install it into the slot the camara screen is just blank, I did get a very faded message saying the the card has to be formated, how can i do this
    Brigadier General:
  • 3,006 Answers
Your problem is that you have purchased an incompatible memory card.
You have an SDHC card, but your camera only accepts SD cards (exactly the same shape, but different internal hardware) up to a maximum 1GB capacity. There is no way to update your camera to the later SDHC standard as it simply lacks the correct hardware to format them correctly, although devices designed to accept SDHC cards can use the earlier SD cards.
You only have two solutions: replace the camera to match the SDHC card, or buy the correct capacity SD card for your camera. In practice, I strongly advise that you go no higher than 512MB as the s500 was happy with some brands of 1GB cards and not with others. This is not a unique problem to Samsung: when your camera was designed 1GB cards simply didn't exist and so hardware compatibility testing was not possible.
I hope you manage to use this information to solve your problem. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 02, 2010
Can i use a sdhc 4gb memory card
Nope, it was made before 4GB SDHC as explained in this video.
May 03, 2013 | Samsung Digimax S500 Digital Camera
I have smasung digimax 4010, I have a 4gb memory card and when I put it in, the light flashes continuously and the Samsung logo is on the screen but thats all.What do I need to do???
You need to get an SD card. The 4010 works with SD and MMC cards. Your 4GB card is an SDHC card. While it fits into the slot it's electronically incompatible and will not work in the 4010. You need an SD card, 2GB and smaller.
Jul 28, 2012 | Samsung Digimax 4010 Digital Camera
I bought an 4gig SD (HC)? card for my Camera. On start up, the Camera reads "FORMAT SET:OK" but when I select OK it Says CARD ERROR!. I've traded the "defective" one in for a...
The A402 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jan 15, 2011 | Samsung Digimax A402 Digital Camera
No ensiende ya mi camara digital samsung s500 digimax
mi camara digital samsung no enciende bien cuando le pongo la targteta de memoria una sd card la pantalla se queda sin imagen y cuando se la quito se poe bien no se que le pasa
Sep 08, 2010 | Samsung Digimax S500 Digital Camera
I bought a 4GB Memory Card for my Samsung Digimax D53. I put it the camera and Try to format it but it says check sd card. I tried another 1GB memory card and it worked. I know that the problem is with my...
Unfortunately, you can't. The D53 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. Since this is a hardware issue, it is not something that can be changed with a firmware update. You need to use cards 2GB and smaller.
May 14, 2010 | Samsung Digimax D53 Digital Camera
Hello, I just purchased a replacement memory card and when I install it is says on the screen "check sd card" after reading the packaging for the new card I realized it says camera may not support SDHC...
HC stands for high capacity meaning 4g or more. Your camera manual should tell you if you can use the card. Maybe all you need to do is make sure the slide switch on the side of the card is unlocked and then you should format the card in the camera.
Dec 08, 2009 | Samsung Digimax S500 Digital Camera
Hi,just bought a 4gb sd card for my digimax s600 but it won,t work.when i switch on camera, screen says..format..yes.confirm ok.when i do this i get check sd card . i put in old card it works fine??..
Does your camera support SD HC? Anything above a 2gb SD card is concider a HC; so if your camera can't support HC format then you can not use that card.
Sep 09, 2009 | Samsung Digimax S600 Digital Camera
Cameras Logo
181 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
