Question about Canon SPEEDLITE 580EX TTL Flash
Frozen on one setting
Hello, My 580EX clicks when I turn it on... the Wide Angle shield is totally in. Plus it is set on ETTL but the Zoom - - mm and the rectangle box is flashing... it will not respond to any buttons pushed or the dial turned. Thanks for your help! Judy
  • 4 more comments
  • zpetschek Nov 22, 2008
    I have the same issue. It tries to zoom out but get stuck somehow in the process. After a few seconds it stops trying and then the screen blinks. It will still fire but I can't change any settings. Does anyone have a quick fix solution before I take it to a repair shop or ghetto rig it myself?
  • aleunge Jan 15, 2009
    Same here! For me, the flash works completely fine at all tilt/swivel angles except regular direct flash position... manual and auto zoom won't work and I get the same blinking --zoom thing. So annoying. Help please!
  • cuisance Feb 22, 2009
    same problem
    yvan
  • zpetschek Feb 22, 2009
    So do you have any information in english perhaps because I don't want to be missing a caution about what not to do somewhere in the writing. My romanian is a little rusty
  • aleunge Feb 23, 2009
    Hi, the second solution below is only for people with the clicking problem, where the zoom doesn't work at any tilt angle and you hear a clicking sound when the flash tries to zoom. In that case, the flash bulb is off the zooming track and popping it back it will fix it.
    Google the link below and hit "translate" this page to get a rough looking English version.
    Anyways, the problem that I'm running into is different. The manual zoom works at all tilt angles except the 0 degree one, where it won't zoom (and it won't click either), and then simply locks up. I've looked around the net, found others in the same situations, but no solutions. Any help will be appreciated... especially the ones that brought the flash into Canon for looking at. Thanks!
  • ronbeeguy Apr 25, 2009
    "In that case, the flash bulb is off the zooming track and popping it back it will fix it."
    When I turn my 580ex on, I get the same clicking sound regardless of the tilt/swivel. Popping the bulb back in the track sounds like the perfect fix, but I can't get the link below to work, and can't figure out how to get into the flash head to pop the bulb back."
Hi everyone. My flash is finally fixed!!!! Like I posted earlier, the problem with the slipped zoom gear head has already been solved and mentioned numerous times... for me though, I ran into another completely different problem.
My problem was that everything works fine (including manual/auto zoom) EXCEPT when the flash is at the direct bounce position (i.e. directly forward or zero degree bounce). When pointed forward or near 0 degree, the manual and auto zoom both won't work. And after trying to either manually zoom the flash from the flash body controls or indirectly/automatically zoom the flash by zooming the lens for a while (with no reaction from the flash zoom head), the flash locks up and I get the blinking "-- mm zoom" thing. In other words, the flash locks up until I restart it.
So having taken the flash opened to try to fine a fix and failing before, I couldn't take it anymore and took it open again. This time, I found that the fault was with one of the wires that went from the bottom half of the flash (the batteries half), through the bounce/swivel joint (where the button is), and then to the top half (the flash output end). The wire was broken inside the insulation from me bending the flash head going from bounce to direct flash. My broken wire was the thin black wire that comes out from the joint hole (not the side with the bounce/swivel button on the joint) to the zoom circuit board. This wire is part of a series of 6 or so colored wires on the board.
I imagine through use, others might break other colored wires than my black one. I had to wiggle and pull each wire that passes through the joint while manually zooming to figure out which wire was the bad one (there's a lot of wires). But I found the b@stard and replaced the wire and I'm good to go now!!! Problem solved!
Hope this helps someone else... and be careful of touching one of those wires that can shock you.
Posted on Dec 14, 2009
I had to take the flash apart and check inside. The zoom mechanism was broken (cut into two halves) so the spinning part didn´t move the flash bulb back and forth.
Martin
Posted on Jun 06, 2009
Try this site and follow the photos.
It worked for me.
327093-how-repair-canon-speedlite-580-ex-dupa-ce-vibreaza-capul.html
Posted on Feb 22, 2009
  • Maple Dec 07, 2012
    OH MY GOSH!... I went to the link... I had it translated from Romanian to English... and followed the photos and I fixed my flash! Wa-hoooo! Thank you for the link!
  • 7 Answers
I've posted an illustrated step by step in English here hope this helps
Posted on Jan 20, 2013
    Champion:
    Scholar:
  • 216 Answers
Hi Judy,
Is it fixed?
atdlee@netzero.com
Posted on Nov 12, 2008
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
My 580EX clicks when I turn it on... the Wide Angle shield is totally in. Plus it is set on ETTL but the Zoom - - mm and the rectangle box is flashing... it will not respond to any buttons pushed or the...
Jack, place the flash on the camera.
Then do the following:
1. Load up Canon EOS Utility software
2. Connect camera with USB Cable to computer
3. Turn on camera
4. Click on EOS Utility
5. Click on flash setting
More help send to my email.
atdlee@netzero,com
Jan 17, 2014 | Canon SPEEDLITE 580EX TTL Flash
Canon 5D and canon 40D are they type A or type B cameras as per 380 EX manual
Hi Bruce,
You have the latest cameras and they will work with ETTL II with Canon 430EX/550EX/580EX and 580EX II. Earlier models use ETTL and films use TTL.
Hope they are helpful.
atdlee@netzero.com
Jan 13, 2010 | Canon EOS 40D Digital Camera
580ex switching from ettl to ttl
I´ve been having the same problem with my 2 580´s. Sent one to Canon but still has the same problem. How did you solve your problem?
Dec 17, 2009 | Canon SPEEDLITE 580EX TTL Flash
Canon 580EX clicks when turned on, cannot push buttons on back
Send it in to canon for service. This is not a simple problem that can be fixed in this forum.
Jan 14, 2009 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 430EX zoom issue
You're gonna kick yourself, but here goes, you know that clear plastic wide beam shield on the front, make sure it's fully inserted or else the auto zoom won't work while it's in use, (or the flash thinks it's in use)
Aug 07, 2008 | Canon Speedlite 430EX TTL Flash
Need to find lense
I think the most prudent solution is to give up on the idea. What do you need that for? This lens already has a huge range of 28 .. 300 mm in film equivalents, and it is marginally useful at 300 mm. Whatever else you put on it will make it worse (less light, poor focus and aberrations). Similarly, at the wide end, while it is technically possible to add a wide-angle element to shorten the focal distance to about 20 mm, that will also result in a loss of light and poor peripheral focus, so you will be much better off taking 2-3 pictures and blending them whenever you need a wider angle. This lens is a miracle of optimization -- it already has the attachments you are contemplating, plus macro and super-macro. I don't think its range can be expanded any further without an unacceptable degradation of quality.
Jul 03, 2008 | Fuji FinePix S9500 Zoom Digital Camera
Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
Oct 23, 2007 | Canon SPEEDLITE 580EX TTL Flash
Flash stopped workin as master in wireless mode?
Hi Joelgue,
Now, go to a real camera store and bring your equipments with you.
Say to them:
I have a Canon 580EX Flash and wanted to know if you have the Quantum Turbo Battery with the Adapter Cord for my 580EX?
Ask to see if you can test them out.
This adapter does not go into the 4AA battery hold but to the flip out cover, AC Adapter. You need to plug it into the flash.
Press "On" from the Q battery, then set flash to "Master" on camera and other EX to "Slave".
Turn all three on(1st flash, 2nd flash and camera.
Do not press shutter button but press the pre-flash(pre-auto lock/flash) on camera body. On the EOS-1Ds Mark III has "*".
Both flashes should come on.
Now, press the camera shutter using "ETTL Modes" and look at the image from the LCD screen...is exposure correct?
Address to this address from now, please: atdlee@netzero.com
PS: You did set both flashes into same channel and with no exposure adjustment, right?
May 25, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon SPEEDLITE 580EX TTL Flash Logo
952 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
