Question about Bushnell Voyager 78-9470 (470 x 60mm) Telescope
The rand and pinion focusing mechanism has twisted off and one part seems to be rattling around in the tube.somewhere. Where can I get this repaired? Or can I do it myself. Thanks.
  • 3,186 Answers
You can buy a new focuser from several on line sources. Here are two-
http://www.telescope.com/control/telescope-focusers
http://agenaastro.com/parts-accessories.html?SID=d6pirrift40nfgsrmhsllep913&cat=66
Posted on Oct 02, 2010
Berger transit won't focus
If you mean your cross hairs wont focus the most likely cause is the cover you are turning is slipping and not actually adjusting the lens. Depending on the model, there are usually a couple small screws that can be tightened to correct this.
If you mean what you're trying to look at (objective) wont focus, then likely the focus tube is no longer making contact with the focus pinion. Look in the objective of your transit, and you should see a tube inside the frame. Turn the focus knob slowly and see if it moves the tube closer and further away. If not the rack and pinion are no longer meshed up. If it does then you have a lens out of place. Disassembly is easy, but reassembly and realigning the lenses is tricky, i would not recommend. A repair shop should be able to take care of this, and make sure it's in proper calibration for not to high a cost.
Nov 10, 2012 | Cst Berger Measuring Tools & Sensors
My 2003 ford focus lost it's power steering, mechanic replaced the rack and pinion thing - lost steering again and now the mechanic says it is the power steering pump. The rack and pinion was replaced...
if the rack and pinion was not leaking or causing problems. then he may of made a wrong move! if the rack was fine before, and you just lost power steering. then it is most likely the power steering pump or the lines that go from rack to the pump. good-day ! if a rack goes bad, you will get a bad steering problem or just bad steering.
Aug 23, 2011 | 2001 Ford Focus
The focal tube on my Meade DS 114 has several stripped teeth. The auto-focus skips and jumps! Where can I find a replacement part (Meade no longer carries them) OR how can I repair this; ie, create new...
You will need to buy another focuser like one of these.
http://www.telescope.com/control/accessories/telescope-focusers/1*25-inch-orion-basic-rack-and-pinion-focuser
http://www.telescope.com/control/accessories/telescope-focusers/2-inch-orion-crayford-style-telescope-focuser
Feb 21, 2010 | Meade DS114-EC Telescope
I have a Canon Digital Rebel XT camera using a 75-300mm telephoto lens. My problem with the lens is that at times it is hard to adjust the focus either manually or automatically with the camera. I hear...
It sounds like the lens has been dropped or knocked and is misaligned in the guides.
Repair against new lewns is a difficult one as prices vary. I would perhaps consider replacing it with a used one. Before you do borrow a similar lens from someone that has the same mount and ensure it is not also a camera problem.
Sep 02, 2009 | Canon Cameras
2002 5 SPEED FORD FOCUS RATTLING SOUND.
it sounds like valves tapping or valve tap, im wondering if Lucas oil stabilizer might help in this situation any other opinions? the fact that it is recommended by so many people including myself, i use it alot
google Lucas Oil / 32 oz. heavy duty oil stabilizer
Aug 20, 2009 | 2002 Ford SVT Focus
Rack and Pinion
Yes you can -- several different telescope retailers sell focuser here is one:
http://www.telescope.com/Accessories/Telescope-Focusers/pc/3/51.uts
You must buy the correct size that will fit your tube.
Dec 22, 2007 | Bushnell Voyager 78-9440 (440 x 12.5mm)...
Bushnell Voyager 78-9470 (470 x 60mm) Telescope Logo
118 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
