Question about HP PSC 950 All-In-One InkJet Printer
"Press enter to align printer cartridges" message repeatedly.
  • stones283 Oct 04, 2010
    It looks like you posted instructions for an HP 2210 that don't work, probably because I have a PSC 950. Can you please provide support for that specific model? I wasted a fair amount of time before realizing it was a link to HPs site with the wrong model. Thanks.
  • HP Master
  • 4,737 Answers
This is another very common issue, in most cases, it related to cartridges and you need to check them or clean them.
First check the Paper, whether they are properly installed or not.
Second, remove all the cartridges and reinstall them.
Third, check the ink levels from the computer through Hp Print Settings.
Fourth, realign the cartridges.
Fifth, clean the cartridges. If possible clean them using a cotton bud dipped in alcohol or acetone or spirit (you have to clean the gold contacts, not the heads).
The detailed step by step tutorial is here (click here).
If the problem persists, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 02, 2010
HP 2210 all in one chg black cart, get message
Do a powerflee of the printer..
take out the black cart. Unplugged all cables
including powercable. press and hold the powerbutton for 30 sec then put back the cable and the black cart.
May 07, 2010 | HP PSC 1210 All-In-One InkJet Printer
Hp 6110 Printer, add wider paper size. Also align cartridge keeps appearing even after I've pressed enter and the process keeps repeating.
Press the enter key and hold it while you press the menu button. That will make the align message go away, but if just one color is missing it will always fail the alignment. The paper size is chosen in control panel and printer properties, printing preferences.
Feb 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Message: "Press Enter to align cartridges" When I do that it starts to do the alignment, then stops and repeats the message. It also won't print.
My thought is that one or both of your cartridges are no good. The printer will not print until it knows the alignment is good.
Nov 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 all in one series printer: align cartridge repeatedly
Bypass the allign cartridge function bu pressand holding settup then press option. The printer will immediately acccept orders.
Apr 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Align Print Cartridges
From the front panel (Macintosh and Windows)Press MENU or SETUP (depending on the model).
Press the right ARROW repeatedly until the display window reads Maintenance.
Press ENTER.
Press the right ARROW repeatedly until the display window reads Align Print Cartridges.
Press ENTER. The unit will begin the alignment process and the display window will read Printing Alignment Page
Verify that the alignment was successful after the page is complete.
Nov 10, 2008 | HP Photosmart 2710 All-In-One InkJet...
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Repeated message to align cartridges
ahh..that's a core function issue..you'll need to do a clean and calibrate for the all in one to work..
and you may wish to renew your drivers here too
Mar 28, 2008 | HP PSC 950 All-In-One InkJet Printer
Printer
This issue occurs if the alignment page is not perfectly or with good colors. Replace the low ink cartridge. If the ink levels are good do the following steps to clean cartridges :
1. Turn the unit on and open the lid or top cover.
2. Remove the cartridges.
3. Using a clean, dry lint-free cloth (a coffee filter works well),
wipe the cartridge contacts, from the top to the bottom. The contact
area of the cartridge should be rubbed briskly to remove the waxy
lubricant material from the gold contacts.
4. The contacts inside the printer may also require cleaning. Using a
clean, dry, lint-free cloth, 5. gently wipe the contacts, from the
top to the bottom.
5. Re-insert the cartridges and close the printer's top cover.
Steps to manually align cartridges
1. Press Setup until Maintenance appears, and then press Enter.
2. Press until Align Cartridge appears, and then press Enter. Two pages are printed, one with instructions and one with patterns.
3. Follow the instructions on the instruction page, then place the page with patterns on the glass and press Enter. The cartridges are aligned correctly.
If the issue persists do the below to by pass alignment :
Press Setup and Options (or Copy Options) simultaneously when align message is prompted on the All-in-One.
Thanks
Dec 22, 2007 | HP PSC 2110 Color Printer
HP PSC 950 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
