Question about NetGear DG834G 54 Mbps 802.11g Wireless ADSL Firewall Router w/4-port 10/100Mbps Switch (NTWRNGDG834G)
Cannot access the internet after installing new NetGear router.
I needed to change to a wireless/4-port switch so that my laptop could connect wirelessly throughout my home. However, after carefully following the set-up wizard to install this new router, the only problem that I have is that my ISP is not allowing me to access the internet. I have Verizon, and the router is a Netgear WGR614.
  • 65 Answers
You need to change the IP address of the router. Plug just the router into the computer. Open Internet Explorer and go to 192.168.1.1. user: admin password:password. On the main page it allows you to change the LAN IP. Make it 192.168.2.1. Now unplug everything and rewire it correctly. This should fix the issue. Verizon uses 192.168.1.1 for the modem well so does Netgear and this causes the network to not function. So changing the IP of the router should fix this issue and has worked for me many times that I have done that set up.
Posted on Jun 04, 2008
3 Suggested Answers
serra_baby
  • 144 Answers
SOURCE: ISP blocking my internet connection.
hello!
-- do you know your verizon username and password?
-- what is the operating system of your computer?
-- have you tried connecting your computer directly to the modem to check if you can get online?
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings, you need to input your verizon username and password on the router setup page then save the settings.
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
Posted on May 30, 2008
serra_baby
  • 144 Answers
SOURCE: ISP blocking access after new router installed.
hello!
-- who is your internet service provider
-- is this working fine before or is this a brand new router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Posted on Jun 11, 2008
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
I have just installed netgear wireless ADSL2 modem router. The wireless works fine on one laptop and iphone but even though my other laptop says it is connected and the signal strength is excellent, I...
is your laptop getting a DHCP address? is it getting the correct DNS? Do this by going to control panel. Network Connections. Right click on the wireless connection. choose properties. double click oo TCP/IP. set to DHCP
Also check your Internet Explorer settings to see if it is using a proxy server under internet options. connection settings. If it is on or set to a proxy server. turn it off.
Mar 06, 2011 | NetGear DG834G 54 Mbps 802.11g Wireless...
How can you use public access on your desktop and netbook with a netgear router and adapter walmart sales lady said it can be done with just the router and adapter setup everything we needed was in the...
Just having the wireless router without connecting it to cable modem or DSL modem will not allow you to get onto the Internet. The wireless card in your computer/laptop will allow you to get onto the Internet at a free public WiFi hot spot location such as McDonalds, Star Bucks, at the airport.
Also the wireless card in your computer/laptop may allow you to connect into an unsecured wireless router from your neighbors, if their wireless router is within range of your computer/laptop but without their permission to use their Internet, it is considered stealing from your neighbor. They have a set download limit from their Internet Service Provider and by you connecting to their ISP you may cause them to exceed their download limit and they would be charged additional costs for every Mega byte over their limit.
Sep 28, 2010 | NetGear RangeMax Dual-Band Wireless-N...
Router not hooked up properly??
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 10, 2010 | NetGear DG834G 54 Mbps 802.11g Wireless...
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of http://192.168.1.99 and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
How to install
look u need three things to connect wirelessly
1. Internet from Provider
2. Laptop with Wireless Card or Desktop
3. Wireless Router
pls check all 3 thingds in place connect an ethernet cable provided by netgear to ur internet provider modem if u have one and see u connect at INTERNET port of router at back
also see where u conenct at modem back there might be only one port so u dont have difficulty in it
then switch On ur Laptop Wireless from the button provided a light will blink with Dish Antenna Type icon or Tower icon then ur laptop will automatically detect the wireless router with name of default or Netgear or something like that
and it will auto connect to router
if u want to setup WEP security so no one else can use ur internet service u can setup WEP KEY for access u can ask me after u get connected
pls rate me WELL !
Jul 08, 2009 | NetGear DG834G Wireless Router
hello!
note:
May 26, 2008 | NetGear WGR614 Wireless Router
hello!
Computers & Internet Logo
282 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
