Question about Cell Phones
Whose telephone number is 02-867-8220 - Cell Phones
How do i find a phone number free
Try whitepages.com. They will provide telephone numbers and other basic info for free.
Aug 29, 2014 | Computers & Internet
Tip
Sorry I wasted £ 6.00. I couldn't understand your comments at all. I...
We had a lot of inquiries with what we call whistling appear to be from different problems which here below:
First case, whistling sound is what we call "Ghosting". To get rid of this sound one needs to put more gas into the system, but more gas will create the suction pipe to frost up and reducing the gas level will create less cooling. The best solution were to full regenerating Freon gas mean remove it filter it out and charge it back. However this will cost more $100 and basically you can leave it and live with it. No harm is created only the sound appears while running.
Second case were with a loud whistling, like a dying bird stuck in your freezer, you likely have a faulty freezer fan motor and you need to be replaced
Third case were with a lower pitched, sort of gentle whistling sound then you have an issue with the door damper, which allows the air flow from the freezer into the refrigerator. And assuming you don't have any cooling problems, it may simply be a normal occurrence, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
Fourth case was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. We found out that the motherboard was probably defective.
Rather than go thru GE, you can found a new one online for 66 bucks. You can replaced it in about ten minutes and it's all fixed.
Fifth the evaporator fan motor should not change speeds in less than 1 minute of time. The fan motor has two speeds. Usually this is a indication of a failing main board. If you have a meter you can do a voltage check at the J-2 connector on the board. Check for 13VDC between pins J2-3 and J2-8 and 8 to 13VDC between J2-3 and J2-4. If this voltage stays steady, your problem lies in the evaporator fan motor. If this voltage drops out or fluctuates, it's more than likely the board need to be replaced
on Sep 27, 2010 | Refrigerators
What is your telephone number
whose number do you want?
Jun 16, 2014 | Computers & Internet
Telefone number for samsung company
In today's modern world it is next to impossible to get telephone numbers. Today, Samsung cellular wants you to contact them via "http://www.samsung.com/us/support/"". Actually it is a better system because one does not have to contend with the techs whose only knowledge source is the screen in front of them. You will get better results using this address on your computer.
Have a wonderful day!
Jun 26, 2012 | Samsung SCH-a650
Dear sir Please give me the Number Detail number is 9936514886
I'm sorry. Not only do I not understand your request but you have posted it on the WASHING MACHINE forum ;-0)
I presume you are after the name and address of the person whose telephone number you give?
You will have to try your telephone service supplier to see if it can help. Sorry again.
Good luck,
John C
Mar 01, 2011 | Washing Machines
Whose telephone no is this 32216009 i need full details like address etcas i am getting calls in the house when no one is there. Bala
try this url to search the owner of that number.
http://www.phonenumber.com/reversephone
Choose from two categories. Either you enter the telephone with your area code. Or by entering your location and the telephone numbers.
Good luck.
Jul 13, 2010 | Lands Phones
+911140549004& +911140549003 , whose number is this.
If you are being harassed on the phone, call the police and report the problem. Then block the numbers.
May 05, 2009 | Lands Phones
Phone number search in hyderabad
how can i know the address with phone number in hyderabad
Oct 16, 2008 | Lands Phones
Cell Phones Logo
78 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
