Question about Dishwashers
Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Hello, I own a Kenmore Ultra Wash Dishwasher model 665. The Lock On light continues to flash red. I reviewed the manual following the instructions of the NO HEAT DRY 'lock button' to hold for 4 seconds to Unlock but this has not worked. The Lock On Light continues to flash red and I'm unable to start a wash cycle. I checked the fuse and all is good. Can anyone advise if your dishwasher has had this issue and how you resolved? Thank you!
  • 4 more comments
  • gln740 Jun 06, 2008
    lock on light won't go off and cannot start dishwasher
  • septarian Aug 21, 2008
    Same problem here.
    There is no "air dry" button. I held the no heat dry button till my finger hurt, but that didn't work.
    My "lock on" button continues to flash. Will not run while flashing.
    Mike
  • kennysh Sep 04, 2008
    I'm having the same problem. The lock on light is flashing. I hold the "no heat dry" button but nothing happens. No other buttons work. Did anyone find a solution?
  • Anonymous Sep 14, 2008
    I have the same problem.  I think the company rigs it that at a certain date it just quits and then you are force to have them come fix it.  I have held the button down for forever and it will not release it.  ANYBODY ELSE NO WHAT TO DO OR HAVE HAD SOMEONE LOOK AT IT?
  • Anonymous Nov 22, 2008
    same problem! All of a sudden the "lock on: is flashing & holding the no heat button does nothing - still flashing! Also tried turning off power to dishwasher with no success. HELP!
  • Mark Huggins Mar 03, 2009
    I have the same problem with "Lock On button". Never used the "No Heat Dry button", so I know it is not worn out from pressing it. Tried all the fixes. Ordered new Electronic Control from Sears Parts. If it doesn't fix the problem, you can return within 90 days and get refund, less the shipping charge. Total cost is $133 which includes $16 for shipping. If this doesn't fix the problem, I will try the Console Assembly, which includes the overlay keypad. It is another $130. If that doesn't work, or if it takes both parts for it to fix the problem, I will return the parts and just buy another dishwasher. Will let you know if either fixes the problem.
Had this issue with our Ultra Wash Dishwasher. We've had it 12 years with no problems. Tried the holding different buttons for 4-6 seconds and sequential buttons with no results. Tried cutting power off and then on. No luck.
A solution on another site gave me the idea to disassemble the inside panel of the door (three screws on the sides and 2 at the latch) to lift it from the front, then lifted the black cover off (trigger points at left and right sides) the electrical area to access the door latch assembly. I jiggled that loose from the door to take a look and it was a bit sticky. Instead of using an air compressor, I dipped a soft bristle toothbrush in rubbing alcohol and liberally cleaned all moving parts and crevices. Hold it over a dish to catch the drips. I wiped it dry with a paper towel real good, blew a little over it to help evaporate the alcohol, then began to put it all back together.
As I was assembling it back, I took notice of how (at the top center on the box side) the metal tab will slide up the black plastic bit and snap down to engage the mechanism (white plastic) that pops the handle as you close the door. It is entirely possible that the tension was not enough to snap it far enough down. I adjusted the tab ever so slightly down. We waited a little longer before restoring the power, just to be certain it was completely dry. I am happy to report the light was no longer flashing! I am running a load of dishes as I am writing this note! Good Luck!!!
Posted on Sep 27, 2012
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
Posted on Jun 24, 2008
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
Posted on May 21, 2008
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Kenmore ultra wash 665 dishwaser wont start. blinking light
The control panel is most likely defective, take it back.
Aug 22, 2017 | Kenmore Dishwashers
My kenmore dishwasher 665-15817 has a blinking ''Lock On'' button
- To clear the flashing light you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Jun 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwashers Logo
2,044 people viewed this question
Top Dishwashers Experts
