Question about Dyson Ball DC24 Bagless Upright Vacuum
The motor runs but no suction. filters have been cleaned
    Problem Solver:
  • 9 Answers
You will have a blocked pipe somewhere which is stopping the suction.
Check all the pipes for any thing stuck. If not find somewhere to have the machine serviced.
Posted on Oct 04, 2010
Lack of suction
You don't say what type of vacuum but it still sounds like a blockage or a split in a pipe... have another thorough look..
Is exhaust air blowing out of the machine... Is the motor running at a higher pitch than normal...?
Apr 16, 2017 | Vacuums
Hoover S3639 Suction Failure/Turns itself off and restarts later
If you did all this already the motor is not having power, must be replaced.
Sep 06, 2008 | Hoover S3639 WindTunnel Bagged Canister...
My QL60 just stopped sucking. The motor and fan run fine.
If the fan is running there has to be suction. If there is none it is because the air in entering via some other port and bypassing the normal intake. Check it out. Check hoses and fittings.
Mar 05, 2016 | Vacuums
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
I have changed the hepa filter & made sure the washable filter is clean. I checked the brush & it's working fine. The indicator is still red very little green. Not suctioning good at all. What...
check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself and you will need to take the unit into the repair shop and have the motor rebuilt or replaced.
c..
Feb 02, 2011 | Bissell 3920 Bagless Upright Vacuum
Power head turns on and works the power that turns vacum on not
If the suction motor doesn't come on but the brush motor does, you have a bad vac motor. If neither motor runs, it's probably a cord problem. Most parts for these are not available anymore.
Apr 30, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Motor runs , but no suction at any of the outlets including the one on the side of the unit
if you dont have any suction coming directly out of the unit then you probably have a full container or a dirty filter. look inside the container up by the motor for a filter that can be cleaned or replaced
Jan 01, 2010 | Broan-NuTone CV750 Central Vacuum
No suction
have u checked all of the filters. I know that when not all the filters r clean the machine will turn on but then it will sound louder and still have no suction. Most times there is a filter under dirt container thats sits above motor and if this filter is not clean the motor cannot breath. Thus no suction
Sep 29, 2008 | Hoover U6630-900 WindTunnel Bagless...
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dyson Ball DC24 Bagless Upright Vacuum Logo
133 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
