Question about Goodman GMS90703BXA Heater
I have a GMT090-3B and its not blowing the air through the ducts. Motor is down below right? Do you have to replace motor or is there something else that I am supposed to try?
Clean the flame sensor with some scotch brite that will do it.
Posted on Oct 03, 2010
  • Anonymous Oct 03, 2010
    My post went to the wrong question.
Ac vents not working
There is a blend door acuator which moves when u change your settings. Its a electric motor. Down under dash, Will need a mech and a heating and cooling diagram to find where the motor is,
Jun 13, 2012 | 2007 Ford Sport Trac Limited
Electric dryer, runs for about 20 min then shuts down, can restart after a period of time, then runs about 20 min and shuts down
you have a bad motor,most likely you don't clean out the dryer,this is the number 1 killer of dryers.the vent line,the duct that the lint filter slides into and the cabinet where the motor is needs to be cleaned out if it's gas once a year,electric once every two years.all a dryer does is move air,when lint starts to build up the dryer starts to run hotter then normal from the lint build up and the dryer can't move the air as easy as when everything is cleaned out and then parts start to brake like the thermal fuse will pop from running to hot or the motor starts to over heat like yours and shuts down.when the motor gets hot the oil that's inside it leaks out,you'll see it stuck to the side wall and on the rear end of the drum with lint stuck to it.there's an overload in the motor that pops when the motor gets hot and after a while when it cools down the overload resets,that's why you can start it again after a while so basicly you have to replace the motor and clean out the dryer,if the vent line is a long run,remove it from the back of the dryer and with a leaf blower blow it out,you'll see all kinds of stuff blow out through the outside duct and clean out the duct that the lint filter goes into and the cabinet where the motor is or replace the dryer.
Apr 08, 2011 | Kenmore 62602 Electric Dryer
I have a 04 galant. The heater won't blow hot air. Went to a repair shop and they said it was temperature control (the control knobs in the car). Replaced that and it still doesn't work. What else can it...
It does blow correct? Just not hot air? This shop replaced the control head (the unit that the knobs are connected to)? I'm assuming the answer to all is yes. There may be a jam. Not too common but I've seen it a couple times. There are doors within the air box under your dash where your blower motor and heater core are. The control head controls these doors, opening one vent door to outside air and/or to the evaporator, closing the other vent door to the heater core or vise versa. It also controls the doors which direct air to certain ducts that will blow out the selected vents. If something has been droped down through a vent and worked its way to these doors I'm talking about, it could jam the door closed that goes to the heater core, preventing heat from blowing through the ducts.
Jan 08, 2011 | 2004 Mitsubishi Galant
Heater fan in 1991 Pontiac sunbird stopped working. We have replaced fuses, and the fan motor. Still not working, continues to blow the fuses. What to do?
Replace the blower motor resistor assembly. To locate the electrical connector for the blower motor resister, it is usually attached to a heating or air conditioning Duct, or the blower motor case. You can also trace the Purple Wire from the blower motor back to the resister. Also make sure that the blower fan is not jamed up with somthing in side and will spin freely,or binding same thing, this will also cause the fuse to blow right away. And does the motor actually spin a bit before it blows the fuse or does it blow the fuse at the same time the switch is turned on? Good Luck and have a good XMASS.
Dec 17, 2010 | 1991 Pontiac Sunbird
Heat and air condition only blow when the control is turned up to high position. And I even tryed replace the control panel.
this problem is caused by the blower motor speed control resistor, it is located near the blower motor, the resistor end goes into the air duct for cooling, replace this p[art and the problem will be solved. See pitcure below, the part is about $13
Sep 23, 2010 | 1996 Dodge Caravan
I need to replace the heater a/c blower motor, how do I.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from remote negative terminal on shock tower and properly isolate to prevent accidental reconnection.
  3. Remove or disconnect the following:
    • Glove box assembly
    • Joint duct
    • Resistor
    • Blower fan and motor
    • Air changeover damper motor
    • Blower assembly
To install:
  1. Install or connect the following:
    • Blower assembly into duct
    • Air changeover damper motor and reconnect the electrical plug
    NOTE Lubricate the damper motor's slide contacts with multi-purpose grease
    • Blower fan and motor into the plenum and reconnect the electrical plug
    • Resistor on the joint duct
    • Joint duct to blower assembly
The blower motor is located on the right side of the heater housing.
  1. Disconnect battery.
  2. Remove the lower right under panel silencer duct.
  3. Remove the blower motor connector from resistor block.
  4. Remove the blower motor case retaining screws.
  5. Lower blower motor case from housing
  6. Remove the fan scroll from motor shaft.
  7. Remove the motor from motor case.
Blower motor (1)
To install:
  1. Install the in reverse order of removal.
Jan 19, 2010 | 2000 Dodge Stratus
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
A/c suddenly stops blowing
Maybe your blower fan is faulty.
The whine you heard could be dry/seized fan motor bearings or foreign matter (such as leaves/twigs) in the fan.
If fan motor is faulty it will need to be removed for repair; but first check as below:-
1) Check fuse is ok.
2) Check motor runs if power applied directly to it. - If motor OK, check:-
3) speed resistor module (usually in fan ducting, in air flow),
4) fan switch operation.
Sep 21, 2009 | 1987 Oldsmobile Toronado
Low air volume coming from supply registers. Checked filter. Checked charge, 40 low/250 high Checked duct, no leaks or breaks. blower turning.
could possibly have a bad blower motor or on the brinks of one. check the run amps of the motor make sure its doing what it should. if not may need new bloer motor
Apr 22, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
79 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
