Question about RCA HD52W58 52" TV
Auto convergence the auto convergence option is gone from the menu and all the colors are messed up.
    Genius:
  • 1,030 Answers
This is an indication of a special fusable link fl231 has blown it is a small brown rectangular fuse that blows due to poor lead free solder connections on what is known as a flyback.. if you can solder and can get the part i find this repair to be a simple one... Caution. televs\isions can hold leathal voltages even when unpluged... EXTREME caution should be taken
Posted on Jun 24, 2008
50 inch rear projection hd ready model r52wm24 colors have separated and picture is bowed toward the middle top & bottom
sounds like the auto convergence option has disappeared from the set up menu. Press menu and scroll to setup and then enter setup menu and see if the auto convergence is still listed there or has it disappeared?
Jul 30, 2011 | RCA Televison & Video
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My auto convergence has disappeared, and my colors are messed up
The ITC222 and ITC222A convergence option missing repair kit fixes tha issue. The kit is available at www.tvrepairworld.com and has complete instructions on CD
Oct 07, 2009 | RCA HD52W59 HDTV Projection Television
I can not find the auto comvergence in my menu
If you do not have convengence when you go to menu then set up convergence should be there.OPEN FUSE FL231 it is on the deflection board Right next the FBT flyback transfomer there are 3 rectangular brown looking caps they are FUSEs the one in the Middle will be open causing convergence failure .They will be on right side of FBT.
Jun 17, 2009 | RCA HD52W59 HDTV Projection Television
The color green has come out of the other colors
Needs to be converged if this is a projection tv. Check menu for a cutomer convergence option. Should be a manual or auto convergence. If you cannot move anything in manual convergence then convergence amplifiers are bad and need to be replaced. Professional can replace no problem.
Apr 09, 2009 | Televison & Video
Auto Convergence Problem, no menu option, 3d looking picture
yes the board components are out.not to replace whole board only two convergence ic on the board needs replacement. they are not at all costly this link which is mentioned belkow has all the instructions to replace the ic on the board just click it and follow the instructions  http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Mar 07, 2009 | RCA R52WH73 Projection Television
Picture(Color Convergence)
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Auto convergence
this point to the special fuse fl231 a small rectangular fusable link. .4 amps if you can get this fuse and you can solder repairs is not to difficult.. you have to resolder connections that cause this fuse to blow
Jun 20, 2008 | RCA HD52W58 52" TV
Auto convergence issues
this is an indication of fl231 fusable link has blown.. a brown recatangular special fuse that blows due to poor solder connections on flyback. IF you can get the fuse and can solder this is not a difficult repair... EXtreme caution should be taken with televisions. this set can hold 380 volts even when unpluged.. rember resolder flyback
May 25, 2008 | RCA HD52W58 52" TV
RCA HD52W59YX35
just found the problem fuse that causes this to happen. The set I have also was not converging, and the auto convergences option was also gone. The small fuse labeled fl231 which is right next to the big plastic piece with the large red wire coming from it in the left corner of the circuit board closest to the back. It is the middle of the 3 small fuses that are smaller than a Chiclets gum. I was able to pull up the circuit board and jump the fuse with some alligator clips and the set looked great again. Every one says watch out for the unit with that red wire SO WATCH OUT!
damortch check out mouser.com I think I found them on there gonna call them tomorrow to see if I can get mine there.
Oct 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W58 52" TV Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
