Question about Nady Systems PMC3 Passenger Driver Intercom - NADY 2-Way Radio
Endless Static Just replaced the batteries before a long trip. The static from my Nady PMC3 is constant and pretty much prohibits use. FM tuner is weak. How do I get rid of the static and restore a clear, static free, level of communication and radio listening? Steve Smith
I can't get my tuner to work, but everything else works fine. All I get is static went I turn to the radio stations on both FM/AM
If you are in a fringe area you might need an external antenna to work with your tuner. Happens.
Oct 15, 2015 | Pioneer VSX-D704S Receiver
JVC-KD-G420 PROBLEM WITH STATIC ON AM - FM FINE
You should check all the connections especially the radio for dust, rust, or any dirt. If that doesn't work then you need some kind of radio adapter to improve you signal.
Jan 19, 2013 | Car Audio & Video
Receiver tuner out after lightning strike
you more than likely have a F.E.T.(Field Effect Transistor) front end tuner,very susceptable to lightning or static charge damage, chech your home owners insurance, you might be able to repair or replace the tuner but it wont be cheap
Sep 26, 2009 | Onkyo HTR500 Receiver
Radio static only but meta data displays
There will be static. A lot of my passengers are surprised that there is static on satellite radio, but there is. Your Sirius satellite receiver "broadcasts" to your car's FM radio through a frequency you select. For example, the Sirius channel on my car radio is 89.1, which is pretty clear and works pretty well on my regular commute. But if I drive beyond that route, where 89.1 is routinely used by regular broadcast radio stations, there is a lot of interference and static. I then have to switch frequencies on both the receiver and car radio, to find another clear channel. Quite a pain. There will be interference. Even the smallest bridge, tunnel, or parking garage often seems to block satellite reception, and occasionally the signal will completely disappear for no reason.
I DID TONS OF RESEARCH FOR YOU ABOUT THESE RADIOS. THE SAME PROBLEM YOU HAVE ARE FOUND BY 100'S OF OTHERS. IT'S THE COMPANY THEMSELVES HAVING DIFFICULTIES.
Sep 14, 2008 | Alpine CDA-9856 CD Player
Bose wave radio static only
Try replacing the battery (turn it over, have a look on the bottom there will be a door for a battery) and then trying it. Alternatively connect a aerial as it sounds like a reception problem.
Jun 01, 2008 | Bose Wave Radio II
FM static
Hi suebu,
So you got it to go with an antenna. FM tuners are real quiet generally unless they get some sort of signal to unmute them. Even a length of speaker wire split for about 100cm each way(this is called a dipole), then hung vertically will get you great reception.
regards
Graeme
Nov 25, 2007 | Onkyo TX-DS777
Radio Communications Logo
Top Nady Systems Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Nady Systems Radio Communication Expert? Answer questions, earn points and help others
