Question about Canon PowerShot Pro1 Digital Camera
Hi whenever I take photoes on cannon powershot sd 500, 5.1mp the image is getting blurred and horizontal stripes appear
    Genius:
  • 1,689 Answers
This looks like a processor fault, or an internal RAM fault. You should send the camera back to Canon for service.
Jerry G.
Posted on Jul 07, 2008
My cannon power shotA4000IS suddenly stop showing/focused pictures the scree show a blurred image of photo taken?
If you are convinced you did not switch the camera to manual settings, and the blur stays, please contact the nearest Canon certified service centre close to you. But before check the settings on the camera and start putting it on automatic.
Sep 11, 2014 | Cameras
Photo has stripes
If your Canon A85 shows similar/ like to below image then its ccd imager chip failure problem and ccd imager will be replaced.
Canon offers free of cost ccd imager replacement for A85 camera.
Click Canon CCD Imager Advisory for details.
Thanks.
Dec 20, 2009 | Canon PowerShot A85 Digital Camera
Overexposure and horizontal-striped image
Hi!
No, it's not a software problem. The problem is that the shutter doesn't work so it can't control the amount of light taken so the pictures are very bright with horizontal lines. There are usualy two causes - a broken shutter cable inside the lens or the shuuter blades are stuck - may happen if the lens get wet or something adhesive gets in it. It's a hardware problem so I suggest you contact local Canon or other camera service center. It is considered a hard repair so it could get expensive. I don't think it's worth it, so I would suggest you get another camera.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot A420 Digital Camera
The image have white blurred images in all modes
CCD Failure !
u are lucky it will be repaired free of charge from Canon even if u are out of warranty bcoz it is a known problem in CCD chips pls see the link call canon in ur region and go rate me FIXYA for help
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Apr 10, 2009 | Canon PowerShot A95 Digital Camera
Cannon s 500 Picture with Just lines
This is a known issue with Canon, it's mentioned on their support pages, FAQ ID: 37383. Horizontal lines appear in the preview picture once the photo is taken. I have a Canon Ixus 500 and I rang Canon UK and they gave me a case number and list of authorised dealers via email for a free repair.
Hope this helps
Ketan Vadgama
k_vadgama2@hotmail.com
Jul 23, 2008 | Canon PowerShot S500 IXUS 500 Digital...
The image is getting blurred
Hi
The camera may have moved when the picture was taken. Try steadily squeezing the button intead of a quick press.
2.Try using a tripod, this could fix the blurred images.
3. faster shutter speed will be needed if you need to hold the camera, and cannot use a tripod.
4. Main reason for the lines could be that the subject is to bright.
A vertical bar of light(red, purple) appears on the LCD monitor/ in the viewfinder This is a normal occurrence in devices containing CCDs (Digital Cameras) and does not mean a malfunction. (This red bar of light will not be recorded when shooting still photos, but it will be recorded when shooting
movies.)
Solution to the last point would be to try and switch of the flash if it is in use. Turn the ISO setting (50, 100, 200) to a lower one as well.
Hope that helps.
May 26, 2008 | Canon PowerShot Pro1 Digital Camera
Flashing horizontal stripes on screen while shooting
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 18, 2007 | Canon PowerShot A70 Digital Camera
Horizontal stripes on images
may be the ink level in ur ink jet printer is low try and use genuine ink for ur printer . i also have the same problem . when i replaced with original ink it gets ok
Dec 03, 2007 | Canon BubbleJet i560 InkJet Printer
Taken pictures appear with horizontal lines
I have the same problem, this is my second cannon sent to me from them!
Nov 16, 2007 | Canon PowerShot A430 Digital Camera
Picture ripples
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot Pro1 Digital Camera Logo
81 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
