Question about Top Knobs M826 Door Pull
If I do not have the key, How do I remove the exterior door know on an emtek lock. I was able to remove the inside door knob with a set screw. I have a rectangular plate on the inside with no visible screws.
    Problem Solver:
  • 7 Answers
There should be a pin set on the outer knob as well. if not the inner knob after it has been removed should thread off, you may need to turn opposite thread.
Posted on Jul 01, 2014
3 Suggested Answers
wiringlunati
  • 576 Answers
SOURCE: I have an emtek exterior door lock, that is stuck
If the opening is on the side, it probably comes off by pushing a small tool (pick or large paper clip) into the hole while turning the key. When you feel the pin move, pull on the knob and it should come off.
Posted on Nov 20, 2009
agent91
  • 2100 Answers
SOURCE: I have an emtek key in knob lock and wont disasemble
The locks are tricky, they have special tools to make it easier, I'm not saying you can't do it, but if you can't get the knob apart, I don't know if you can get the pins in the tumbler right. Usually a pin hole in the side of the knob will release the keyset, then the ring in the back will release the tumbler, the cap on the top will release the pins, and I mean release, hang on to them, cause they fly! Put the tumbler back in without the pins, put the new key in, make sure it is right, drop the pins in one at a time, first the bottoms, they should all be the same size, then the tops will be according to the cut in the key. Or is it the other way around, drop in the springs, put the cover on, if it works the first time, you will be very lucky. Hope this helps.
Posted on Mar 20, 2010
I have an exterior screwless doorknob that I need to remove. The faceplate on the inside knob that covers the screws is also covering the little pin that removes the knob. Is there another way to remove...
There is the 3rd version of the Kwikset exterior door set. The interior face plate is removed and on each side of the base plate has small slots with a lever on either side that need to be moved to the other end of the slot. The whole interior knob assembly with come off.
Dec 23, 2011 | Kwikset Locks & Locksmithing
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
Schlage deadbolt will not unlock even with the use of a key?
it sounds as though the linkage that pulls the deadbolt back has disengaged... if you undo the screws from the inside of the door and remove the manual knob there will be 2 more screws holding the key lock to the door. A thin flat bar is attached to the key lock that goes through the deadbolt and into the manual knob. This bar turns with the key, sliding the bolt on its track to lock and unlock the door. Once the lock is apart check the key in the lock to see if the bar turns when the key does. then see if there is anything that may be obstructing the deadbolt from sliding. The locks are pretty indestructible so if there is a problem it may have been from the install... perhaps the door is to wide for the lock to engage properly and the lock worked loose in the 6 months that it worked.
Jun 21, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Mar 20, 2010 | Top Knobs M826 Door Pull
I have an emtek exterior door lock, that is stuck in the locked position. I can only open it with a key, and not even the inside unlock mechanism will permanently unlock it. I took it apart as much as i...
Nov 19, 2009 | Top Knobs M826 Door Pull
The door knob (lever door knob to exterior fancy door) came off.
When you first tightened the screws, the mechanism may have been loose enough to allow the actuator bar the connects the inside knob to the outside lever to work loose. When you tightened it you may have jambed that tight so things didn't work. When you disassembled everything, you may have lost that part. The springs are usually integrated into the catch part and are not removeable. Sometimes it helps to take everything completely off the door including the catch that goes in the edge of the door. Then reassemble it on a table to see what works and what doesn't. If that doesn't help, take all the pieces into Lowes at the key desk and they will be glad to help you.
Jun 18, 2009 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Can't take apart an EMTEK entry set
Hope I can help! I have worked with Emtek before and some of the front plates are secured with screws from the the other side of the door. You may want to check if this is the case. if so remove the screws so you can remove the exterior plate. Best of luck. Hope this works!
Nov 18, 2008 | Hardware & Accessories
Top Knobs M826 Door Pull Logo
262 people viewed this question
Top Top Knobs Hardware & Accessories Experts
Scott Jelt
Scott Jelt
Rob Benoit
Rob Benoit
Level 1 Expert
woodzowl307
Are you a Top Knobs Hardware and Accessory Expert? Answer questions, earn points and help others
