Question about Detecto PD100 Platform Scale
The scale won't zero - Detecto PD100 Platform Scale
My scale reads full when i turn it on whats wrong
Most scales will have what is called the "TARE" button... push the "TARE" button when nothing is on the scale and it should 'zero-out.'
Once it is zeroed, it should give honest weight readings.
May 13, 2016 | Health & Beauty
I bought a pierre cardin digital kitchen scale YHC1407C online including battery.is the battery inserted properly when u packed or should we insert it.the machine is not responding on pressing TARE...
If the scale is ''on'' then the battery is in correctly. ''Tare'' is used for making the scale read ''zero'' when a ''holder'' (such as a cup or plate) is placed on the scale and you want the scale to be at ''zero'' with that item on top of the scale. With nothing on the scale, the tare button will not do anything. Also, you have to hold down the tare button until the scale actually displays ''zero.'' (Perhaps you are just ''pressing the button'' and releasing it? You need to press and _hold_ the button down until the scale actually reads zero).
Jan 01, 2015 | Cameras
Zero range error? the keypad is locked. what to do?
The zero range error means when the scale is switched on and the weight on the pan is above the zero range for the scale.Thanks
Sep 12, 2014 | CAS CL5000 Label Printing Computing Scale
Avery H500/L200 Avery Weighing Scales For ForkliftTruck When scales powered on, screen displaying ''balance limit''. Scales will not function.
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Sep 28, 2011 | Health & Beauty
ERR12 AND16 KEEP COMMING UP NEW SCALES unable to reset
Err 12 Inital load is too high power on zero point outside permissible range
Err 16 No zero point available, unable to calculate weight
Check no load on platform
Check the sensor this could be defective. This is the most likely
Sep 02, 2010 | Seca 354 Digital Baby Scale Pediatric...
My health o meter doctor's scales model 230 will not balance at zero
Hi. Cldchasr is talking about an electronic scale, not your beam scale. Coachphil was helpful but inaccurate for this model. I have a 230. Use Coach's method but there is no screw on the left to adjust. Instead, use the black zero balance at the upper left. Move the black slide on the silver bar until the scale balances.
Aug 08, 2010 | Health-O-Meter 500KL Medical Scales...
How do you zero out a health o meter weight tracking scale?
After stepping on the scale to Activate your number (1-4), hold it down and it will say "reset" or (something to that effect), then Yes, or tap it once and it will say "no". If you want to reset, when it says "Yes", continue to hold it down, and it will then reset to zero.
Jan 25, 2010 | Health-O-Meter Health O Meter Weight...
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Balance beam scale
First, with scale empty, set all wieghts to their zero positions. Set zero adjustment so that the indicator is on zero. Place sample on scale and, working from heaviest to lightest, set each wieght to one notch less than what would overange indicator. When all wieghts have been set add the values of each wieght position.
Oct 23, 2008 | Baby Gear
Detecto PD100 Platform Scale Logo
29 people viewed this question
Top Detecto Health & Beauty Experts
Louis Smith
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you a Detecto Health and Beauty Expert? Answer questions, earn points and help others
