Question about Philips 9P6040C 60" Rear Projection Television
My philips magnavox tv is showing alot of red. the blue works a little and the green is out. the model # is 9p6040c104. how would i fix this problem?
  • Jonathan Rice
    Jonathan Rice Mar 23, 2015
    I am looking for one of these tvs. If you would sell it please let me know. Jonathan Rice 914-682-4722
    Problem Solver:
  • 14 Answers
Sorry
Recycle it correctly.
Sorry Mark
Posted on Oct 02, 2010
My tv model 60P8341A philips television screen is red and dull in color what do i need to do?
Hello
If your TV screen looks more red its red video output section is in trouble. Some philips circuts uses transistors while others uses ICs in that section. Philips magnavox model have both types. We here in India, have transistorised video output stages in Philips Magnavox sets. Whatever the ciruit type may be, the fault and its remedy is same.
Check whether your set has transistors or ICs used. If transistors are used, check the collector voltage at red video output transistor. If ICs are used, some sets uses a single IC for Red, Green and Blue output stages. Some of them have three ICs on board as Red,Green and blue output stages.
The video output stages are integrated on the base card of your TV. That is, a small square or rectangular board, pluged into the neck of the picture tube. You just find out the red,green and blue output transistors, or ics whichever may be used. It is ver easy to understand the video output transistors. They may be a little larger than other transistors.
An easy way is to locate the Red,Green and blue cathodes of the picture tube base board points. Check the voltage of the three of them They must be almost equal to each other, provided a little, that is, 2 or 3VDC difference is allowable and will be. In your case, the voltage at the red cathode may be , not may be, must be low. As cathode voltage lowers, emmision of that cathode will rise, and poise that colour is in excess. If the Red Cathode voltage in your TV is found low, say difference betwwen other two cathodes is 50v or so, repace the red output transistor or the Ic if used at that stage. If a single Ic is used in your TV as R_G_B outputs, replce the same. If three Ics are there, replace the red output control Ic. ok
If you have any more problems, inform fixya. They will send me alerts.
Thank you
Oct 20, 2010 | Philips Magnavox 27MS343S 27" TV
I have a Magnavox 51MP392H/17 Rear projection TV. about 2 months ago the color start to merge into each other and showing double. I would cut the TV off...wait a few minutes then turn it back on and the...
yes its repairable
its a convergence circuit failure there are a couple ics and most likely some resistors that will need replacing and possibly a pico fuse
est 300 to 340 you mention only red and green though do you not have blue in your picture
id bet the blue is non exsistant and will need a blue liquid kit changed to correct that problem also
you might want to conatact a local servicer and give a model and ask them what they woud do both for then you can make a decision if you want to do it or not
Oct 31, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture fuzzy and brighter in center. convergence good on red but blue and green only show in center crosses. green and blue glow around figures.
Ur convergence is dead,must be placed.U know how to solders?Tries these wesites for convergence kit.Tv repair World.com,Tv Repair Kits.
Oct 23, 2009 | Philips Magnavox 9P6034C 60" Rear...
Connected my monster cable component to my tv but no video worked last week tv is good could it be my playstation3 or the cable
Make sure you pluged the color coded cables up correctly, Green to green Blue to Blue and Red to Red. Sometimes in low lighting you can confuse the green cable with the Blue...
Oct 20, 2009 | Philips Magnavox 51MP392H Rear Projection...
PHILIPS MAGNAVOX Picture Color Off
hi i hope i can help you?. please check the arial connection. may i please ask you if you open up . go to where the red light is and check for any adjusters.if you find turn down the red top tip if you use a mirror and place in front of the tv and tha t way you will see what is hapining.
May 08, 2009 | Philips Televison & Video
Projection tv
the blue gun is not working properly which explains the dominance of green and yellow colors. you need to look after dry-joints on the blue gun circuit board, sometimes oil leakage from the lens may also affect the board
Mar 26, 2009 | Philips Televison & Video
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips projection tv
sounds like your cooling fluids in the tubes needs to be changed. Repairman told me it was common on the philips.
Sep 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 9P6040C104
i just found out why, turn on ur tv and remove back look directly into 3 lenses, if the picture is not nice and clear or looks snowy in all 3 u will not get good color or brightness. I removed my blue tube assembly and took it apart WHILE OUT OF TV. there is cooling fluid between lense and tube, this fluid over time will build a film on the face of the tube and get thick enough to block the tube from projecting picture. (MARK EDGES IT GOES BACK TO GETHERE THE SAME WAY IT CAME APART).Find some new fluid then carefully dissasemble and clean interior of lense, housing and tube thouroughly. Reassemble and fill with new fluid. Do not use old fluid it will be cloudy and snow globe effect. Only do 1 tube at a time this will allow u to realign cross manually as close as possible before u perform convergence. Leave the green for last that is the center and the red and blue are moved to match green. Also be sure to clean mirror and back of screen. Pete
Aug 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 9P6040C 60" Rear Projection Television Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
