Question about Compaq Armada E500 Notebook
What is Dry Boot of laptop and how to perform it?
    Guru:
  • 1,082 Answers
Dry boot is a way to reset HP laptops. Sometimes it works and sometimes not. Here is how to do it.
Disconnect the power cord, remove the battery, press and hold the power button for about a minute. Then re-insert the battery and power cord and try to turn it back on again.
If you are still having the same issue, remove the battery but leave the power cord and try to turn it on. Oh yeah, disconnect any USB devices and a monitor (if you connected a monitor to your laptop), make sure there is no disc in the drive either.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Posted on Oct 02, 2010
    New Friend:
I am even facing the same problem,but this dry boot really helped to solve my problem. so will it be good to perform this dry boot daily
Posted on Aug 02, 2013
Can i use pc 133 in place of pc100 on a compac armada e500 ?added 2-256 133 and it turns on but nothing on screen
Posted on Apr 08, 2011
SOURCE:
How do I fix Acer Travel-Mate 5744, The laptop cannot boot. There is a brief Brand Name Acer and then it goes back off.
Heating the motherboard enough to repair a dry joint is rather folly. It will do more harm than good unless you heat both sides simultaneously at controlled temperatures..
Remove hdd and RAM. See what happens when you try to boot. You should get a DOS screen. If not, replace the motherboard.
Feb 06, 2016 | Acer TravelMate 5740-5896 - Core i3 350M...
My Samsung rv515 0a5ca wont boot, but the power light Still on
Hopefully if you have all your files backed up, perform a System Recovery with your operating system, or better yet, You may restart your laptop and tapping F8 at the same time, perform a system recovery thru the Safe Mode.It may be a corrupted software with the "boot.vis"
file.??This is the best i can do without seeing your laptop.
Aug 23, 2014 | Samsung RV515 Laptop
Laptop always hang
Peripheral Issues
USB drives, inserted before boot, will cause a hang. Remove all such devices and media (such as CDs and floppy disks) before booting your laptop.
Software Causes
Press "F8" at boot and press "Last Known Good Configuration" to take your laptop to a previous working boot. Starting your laptop in "Safe Mode" by pressing "F8" at boot will help you check for software causes for a hanging laptop. By turning off unnecessary processes, this mode allows you to run anti-spyware and antivirus software to clear malware that hinders performance. Perform a check disk by right-clicking on your "C Drive" found in "My Computer." At the "Properties" link, press the "Tools" tab to schedule error checking. Reboot your laptop and let it perform this check.
Hardware Causes
Verify that your RAM is seated correctly by removing it carefully from under its access door on the bottom of your laptop and reinserting it. Do not touch its gold contact points, as this may damage the memory. Download the hard drive manufacturer's diagnostic software to test the integrity of the hard disk. If you have access, run a professional hardware diagnostic suite to check the motherboard and CPU. Boot with the battery removed to verify that there is not an issue with power conflicts.
Final Considerations
Checking the "Event Viewer from Administrative Tools" located in "Control Panel" (XP only) can also shed light on potential causes. Performing a repair installation of Windows can address missing files, registry errors and corrupted system files without damaging your data. This process requires your original Windows disks but is often quite useful.
Sep 22, 2011 | Computers & Internet
How do i reboot my acer laptop to get rid of my virese
Boot your laptop hold down F8 boot to safe mode with networking. Open your web browser google malwarebytes anti-malware download and install it. Perform a quick scan. You may also wish to try http://onlinescan.avast.com
Sep 06, 2011 | Acer Aspire 5500 5570-2609 Laptop
Water spill on keyboard
Remove the battery immediately,remove the water and place the laptop in a warm dry place for a day or so until it is completely dry.
When you replace the battery and boot up the laptop, hopefully no damage is done.
Aug 14, 2011 | Toshiba Computers & Internet
I cant type nothing in my laptop is locked and i dont know how to fix it can you please help me
Hello Christinaple,
Please perform a dry boot on the notebook to solve this issue.
* Turn off the notebook.
* Unplugg the notebook from the AC adapter.
* Remove the RAM and Battery and reconnect it.
* Now try to turn on the notebook
This issue usually occurs due to static charge.
Regards,
Dr Tony
Jul 23, 2011 | Computers & Internet
Soda spill on inspiron
Okay shut it down, do not try to boot it up!! You want to first open the lid as far as it goes and turn it upside down to try and get as much of the liquid out. Then you want to remove the keyboard and all covers from underneath the laptop use compressed air to dry the laptop as much as you can, then with some alcohol and small brush clean soda residue let sit and dry for at least a couple of days. Then re install battery, keyboard and all covers. Then try to boot it up. Hopefully you did not short out the motherboard, or mouse pad and keyboard. Good luck.
Mar 10, 2011 | Dell Inspiron 1525 Notebook
My Aspire One D250-1165 can not boot. I was asked to insert boot disc and press any key. The problem is i lost the disc that came with it. what do i do now? and how can you help?
You could contact the Acer customer care and ask them for a new boot disc. Of course, that will cost.
Or, if you can arrange for it, just take any windows CD, boot into it and perform startup repairs. that should solve any boot loader issues.
Also, most laptops these days come with some sort of recovery drive in them already. isn't there anything like "Press F5 for recovery" or some similar message. Going into that and performing the startup repairs should do just fine. then, you can create some recovery CDs or DVDs for such a rescue the next time.
Mar 05, 2011 | Acer Aspire One PC Notebook
The unmountable boot volume message is on
perform 32 bit diags on hdd using drivers disc, if no error, boot your comp using windows disc and perform recovery console, perform chkdsk /p
Feb 23, 2010 | Dell Inspiron 1545 Notebook
Speed of harddisk
Run A disk Defragmentation By going to
My Computer -> Right click on C: -> Properties -> Defragamtion
Nov 27, 2008 | Computers & Internet
Compaq Armada E500 Notebook Logo
2,690 people viewed this question
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
