Question about GE Dryers
GE DRSR495EG electric dryer turns on, will not heat, motor works and is hot, but no hot air.
  • GE Master
  • 8,220 Answers
Well it is not the fuse. Because you say it runs but don't heat. It probably is the heat element. The only way to know is to check it. (how to restring a heating element)
GE DRSR495EG electric dryer turns - 4521e8e.jpgee2d15e.jpg69c6326.jpg49GE DRSR495EG electric dryer turns - eeca90c.jpgclass=More Here
Posted on Oct 02, 2010
GTDX100EM1WW GE Electric Dryer smells hot and electric cord is very hot Problem not present on air dry. Vent is connected and air blows through. Cord is quite hot to touch at the outlet.
Usually the motor, if you're not experienced, better to have a service person come out. Almost always the motor in the dryer that causes this
Oct 10, 2011 | Dryers
WON'T DRY CLOTHS..NO HOT AIR
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';';
Jun 27, 2011 | GE Dryers
My GE Dryer.. serial number GL 733 568A. Do not dry clothes, everything else work, except getting hot enough to dry. The dryer just blow cool air..
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | GE Dryers
My GE Harmony dryer has stopped heating. All of the cycles work (air comes out), it just wont get hot.
heatman101
Sep 17, 2010 | GE Profile Harmony DPGT750EC Electric...
Ge Profile Electric dryer model DPSE810EG5WT The
Hi.
If the fan does not work at all,then the fan motor must be replaced. The fan is tested jumping its contacts to energize it directly.
More commonly the problem is clogged air ducts. Check lint filter and check ducts for blockage. Ensure that the air duct is well in place.
Jun 27, 2010 | Dryers
Dryer runs but does not get hot and dry
It runs since the motor is still working and turning the drum. No heat since the heater element is broken so no heat got produced to dry clothes. Replace the heater element to correct the problem. Good luck
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
124 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
