Question about Gestetner Office Equipment & Supplies
Gestetner sdm721d with error code sc 302 could you please help me
4 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Posted on Oct 04, 2008
  • 86 Answers
SOURCE: Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
Functional problem sc 302 in ricoh photocopier model aficio gestetner 1802d, pls help me out, nobody want to help i begged you all. mordecai Olugbenga.
that is a charge roller leak error. try a different photo conductor see if it goes away. If so could be charge roller bad or drum . if it has more then 60,000 copies on it rebuild it .
Mar 04, 2017 | Ricoh Office Equipment & Supplies
Gestetner mp1900 error sc 302
Problem is charge roller clean Charge roller current leak
Apr 15, 2014 | Office Equipment & Supplies
Error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
@wAm getting a sc 302 code on a gestetner mp 171.I have changed the whole drum unit.
Hello!
When you change the PCU did you conect the blue plug????
If this is not the case remove the PCU again and if you look deep down you will see a metalic shaft. Clean it and install again the PCU.
Hope this helps you
Aug 01, 2011 | Ricoh Aficio 2015 Copier
I have Nashuatec SDM 616 photocopier. I was doing copies when give an error code of SC:302. Please explain the code for me so that my service can use it to service the machine. Thank u
This code is related to a current leak in the Charge Roller.
The first thing i advise you to do is clean the plug of the PCU (fotoconductor unit) and of course the PCU.
If you take out the PCU you will see a metallic pin and a spring (in the back of the machine). Clean it or vacuum it (could be dust of toner).
This should be it.
If that doesn't work you probably have a defective High voltage supply board.
Hope that helps
Mar 03, 2011 | Gestetner - DSM-616 COPIER Copier
Black picture and then sc-302
sc sounds like a scanner code check and see if scan lanp is on when copying. just lift the top cover and hit copy.
Jan 22, 2011 | Gestetner Office Equipment & Supplies
"A"
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
48 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
