Question about Garden
Rented Makita LS 1011 Manual. cannot move guide to 45 degree angle cut. Have no manual.
  • 8,197 Answers
You can get the manual on the link below. Just scrool down to Product Details then click on manual.
http://www.amazon.com/Makita-LS1011N-10-Inch-Slide-Compound/dp/B0000223I8
Good Luck Please rate 4 thumbs up and please leave a Testimonial
Posted on Oct 02, 2010
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
The saw is hard to move to the angled positions. You have to really pull on it to get it move
I used a power saw every day for years. Makita is a good brand. We used Milwalkee and Craftsman. My Milwalkee, I used the side of my hand to hit it into place >> I didn't hit it real hard, but the angle setting should move a bit sluggish so you can get to the correct cutting degree using one hand while holding saw in other hand. If the angle setting is floppy loose, you have to use two hands to get it set.
The whole guide assembly should come loose from the motor part. Take it apart. Remove the dust & dirt. Spray a bit of WD-40. It should be good to go. Remember the saw is your friend so cut straight and fast.
Up-vote if this helped. Thanks for the feedback.
Oct 14, 2010 | Makita Saws
It doesn't give me a precise 45 degree cut
the fence might be bent or needs to be squared up. how is the 0 degree. If you need to find out how to square this tool go to Makitatool.com and type in your model number and you can download a user manual with the instructions on how to do this, let me know I work on them every day. Good luck
Jan 20, 2010 | Makita 10" Dual Slide Compound Miter Saw...
Directions on how to use a square to cut common rafters we have a stanley squ and no manual, on use
A standard square is used primarily for drawing 90 degree angles. Simply hold the fat side of your square firmly against the length of rafter. The skinny side of the square should be lying accross the rafter, forming a 90 degree angle with the side. Use a pencil to draw a line along the edge of the square and use this line as a guide while sawing the rafters.
Sep 27, 2009 | Carpenter Stanley 45-500 Handyman Steel 's...
I cannot get a perfect 45 degree angle with my Makita circular saw. Is it me or the saw??
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Jul 29, 2009 | Makita Saws
45 degree cut
loosen the miter lock, tilt the table to 45 deg. tighten the miter lock
Feb 19, 2009 | Makita 7 1/4" Circular Saw 5007NB
I have a makita mitre saw and need to adjust the angle to 45 degrees. I unlock it and try to turn it but it won't turn. Any ideas?
you have to turn the handle, it works like a bolt, you cant see it but it is tied in, you have to unscrew it before trying to move it
Dec 13, 2008 | Makita 10" Dual Bevel Sliding Compound...
45 degree cut
Are you having problems with the miter or bevel ? Are you asking how to physically move the saw to that degree angle?
Nov 17, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
