Setting VCR to record at a specific time from TV
I need to know how to set the VCR to record something from TV if I am not home at that time (ie delay recording). I have aquired this VCR from my father and it works well, but of course no handbook!! Can you please help.
  • blarney Jun 05, 2008
    I also inherited a Orion VCR without a manual and am trying to record everyday and the same time, but can not get it to work. Any advice would be appeciated.
Press buttons such as "Menu" or "Timer" on your remote and you should see a place to set the times for recording. Try using the fast forward button on the remote to get to the next level of an item on the menu
Posted on May 31, 2008
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
Lorex security camera
Coax from camera needs to feed vcr, at line in, line out from vcr goes to input of tv ie av1 av2 video in what have you. go that far and see if it makes sense.Then you can set vcr to record continuous and watch it at same time on tv or monitor.
May 14, 2017 | Lorex Home Security
I would like to record a show/shows on tv using my lg gc990w 6 head hifi stereo vcr . A work colleage has told me I cant do this because I am trying to record a high definition channel. Is this true or...
you can try setting your tv to record and your vcr to record at same time,,,i have digital tv and set record time,,then on vcr set to record avi at same time,,the only problem is the tv turns itself on when timer starts,, hope this helps and makes sense,,cheers.
Feb 08, 2011 | LG Televison & Video
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
I have a Panasonic VCR PV-V4202-A. I want to
You need to go into the menu and look for timer recording,then set in the channel,dateand time the program starts,then press the timer button.It will not start recording until it gets to the time the program starts.
Sep 11, 2009 | Panasonic PV-V4022 VHS VCR
I MISPLACED MY USER MANUAL
You have to go the main menu and select record times, and day. Make sure you leave your tv set on, and on the channel that you wish to record the program on. You can set the start and stop times a few minutes before and after on the vcr, just to make sure you get the whole program. You can also set the vcr to record this program every day, any day of when ever you wish you can just manually hit "record on the vcr remote. Good luck, let me know how you make out! Thanks
Aug 12, 2009 | Televison & Video
Ambiuous Information out there
I kind of think the people that wrote the manuals didn't bother hooking up a unit. Here is some help.
The converter box is nothing more then a tv tuner that picks up a digital signal and converts it into analog so your tv can view it.
The vcr, to record programs has to be set to channel 3 or 4 (whatever the converter box is broadcasting on) to record. The converter for the vcr will have to set to whatever channel you want to record from every time you use the vcr and left on as this is the only was the vcr can pick up a signal. Make sure the power saver on the converter box is set to off.
If your tv converter box has digital pass through, all you have to do is turn the tv converter box off and it your tv should pick up the singal from your vcr when you play tapes. You also use this method to access the menu on the vcr.
Jun 04, 2009 | Insignia Digital-to-Analog Converter for...
Can no set date on VCR past 2008
dig around for old calendars or maybe the internet. compare dates. like for example. (my birhtay) july 12 in 1998 was a sunday. in 2009 july 12 was also a sunday. so u know that all dates in 2009 will line up with 1998. so in setting the vcr, make like its 98.
May 03, 2009 | Televison & Video
Trying to help this older lady with a emerson tv/vcr combo. She has no manual with set. Setting up to record same station everyday at same time. VCR will record but when playing back she only gets sound no...
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
Jan 08, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
How to set up to copying a video tape.
This is a snap, as long as you have a second VCR if not you can't do it.
1. Hook the out put line(s) from VCR1 to the input line(s) on VCR2.
2. Put recorded tape into VCR1 and press play.
3. Set VCR2 to the channel that VCR1 is playing on, it's usually 3 or 4.
4. rewind the recorded tape and put the blank into VCR2.
5. Press record on VCR 2 and play on VCR1.
if you want an exact copy stop here. . . or
6. pause VCR2 when ever something comes up you don't want to record, ie a commercial if you'r re-recording a movie from TV. be for warned though each time you re-record an analog recording, like a VHS tape, the audio and vido tracks get further and further apart. After about the second or third time you re-record a tape you'll hear something before you see it, or vice-versa. I hope this helps you out.
Dec 24, 2007 | Emerson EWD2202 DVD Player/VCR
Open Questions:
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
