Question about GE JVM1750SMSS Microwave Oven
3 yr microwave just turned off after use. Would not accept any buttons pressed. Checked fuse and turn off and on, but microwave does turn on....please advise.
  • GE Master
  • 9,098 Answers
If the fuse were bad, the oven would be totally dead.
The rest of my answer assumes a model number of JVM1750SMS01 / JVM1750SM1SS.
You have a failing membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part number to order is WB07X11054 and you can get it from the Pros here for $129.93 plus shipping. They're our favorite supplier.
You can also find helpful exploded view diagrams at that link.
Posted on Oct 02, 2010
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
Microwave oster
could possibly a blown internal fuse .
Jan 23, 2018 | Oster OGH6901 0.9 Cubic Feet Digital...
The "under the microwave" light was on. All of a sudden, the light and clock stopped working. We have checked the plug and checked our fuses. Are there any troubleshooting suggestions out there? Thank...
There can be several fuses. Some on the board and some encapsulated in white plastic along wires. Do the buttons work (beep) when you press them? Is there any sign of life?
Oct 08, 2013 | Whirlpool WMH2175XVS Stainless Steel 1000...
Is there a reset button on frigidaire microwaves. have already checked the circuit breakers but still not working
nope sure isnt, if it doesnt turn on you may have just blown either the load in fuse or the high voltage fuse down the bottom, remove the cover should be a couple screws round the outside and check fuses if you know how (MAKE SURE ITS UNPLUGGED FROM THE POWER FIRST) (NEVER START THE MICROWAVE WITHOUT THE METAL COVER ON AS THIS ACTS AS A RADIATION SHIELD)
Mar 26, 2011 | Frigidaire FGMV185K Microwave Oven
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Mar 21, 2011 | Emerson MW8107WA Microwave Oven
The microwave won't turn on. it is off completely. Just happened last night. Have checked the electric fuses, poked the buttons, but noty on. Stove is ok.
You have to open it up and see if you can find the power fuse, usually a BUSS 15amp Slo Blo that protects the Microwave Tube from drawing too much current and causing a fire. These fuses degrade over time or some get through that are not quite 15 amps and blow.
Dec 19, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
Display is reading locked.
Press "Clear/Off" button for about 5 seconds or longer and it will unlock
Dec 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
GE JVM1750SMSS Microwave Oven Logo
176 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
