Question about Whirlpool Washing Machines
Control lock button is on and will not go off.
  • 868 Answers
Hold it down for 3 seconds
Posted on May 26, 2008
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I cant unlock it
When you enable the Control Panel Lock function, you can lock all of the projector's buttons, or all of the buttons except the Ppower button. The remote control can still be used to operate the projector.
1. Press the Menu button, highlight the Settings menu, and press Enter.
2. Select Control Panel Lock and press the Enter button.
3. To disable the Control Panel Lock function, select Off in the Control Panel Lock menu.
4. Select Yes and press Enter to confirm the setting.
5. Press the Menu button to exit.
*- Or press and hold the Enter button on the projector's control panel for seven seconds. A message is displayed and the lock is released.
If you need a manual for your unit, goto here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=140128&prodoid=63085205
and click "Users Giude".
Jun 19, 2012 | Epson Powerlite S7 3lcd Video Projector,...
My washer has the control lock on how do I unlock it?
The Control Lock is unintentionally turned on. Press and hold the End of Cycle button until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fails to unlock it. The control can be locked by pressing and holding the same button until the Control Lock light turns on.
Oct 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock on
To enable the Control Locked feature when dryer is
running:
Press and hold the CYCLE END SIGNAL button for 3 seconds.
The control is locked when a single beep is heard and the Control
Locked status light is on.
 When the dryer is off, it is not necessary to press the Control
On button before activating the Control Locked feature.
To unlock:
Press and hold the CYCLE END SIGNAL button for 3 seconds to
turn this feature off.
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Off button, but can’t be
restarted until the control is unlocked.
Jun 01, 2010 | KitchenAid KGHS01P Gas Dryer
How do you turn off the control locked key?
running:
Press and hold the END OF CYCLE SIGNAL button for
3 seconds. The control is locked when a single beep is heard and
the Control Locked status light is on.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds
to turn this feature off.
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
May 29, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked light is on
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
running:
To unlock:
Here is a manual.
Apr 10, 2010 | Whirlpool GEW9200L Electric Dryer
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
NOTE:
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De GO PATS
