Question about Frigidaire Affinity ATF7000E Front Load Washer
Ran through cycles fine untill it got to spin cycle then stopped and started humming and did not drain all water out
    Brigadier General:
  • 3,006 Answers
The pump has either blocked or failed. The humming noise strongly suggests a blocked pump, but if left that way for too long the pump motor burns out.
I'm unfamiliar with your machine as it's not sold on my side of the Atlantic so can only provide a generic answer, but most front loading machines have a user-accessible pump located behind an access panel at the lower front of the machine.
Turn the machine off at the main power socket and open the access panel. The pump is usually hidden behind a circular access about 3 or 4" in diameter, but if you open it then the water in the machine will gush out. Many machines incorporate a small drainage tube next to the circular access, you pull it out and place the end into a large bowl and then remove the plug on the end to drain down. Once the water is drained , replace the bung in the tube and re-stow it as you found it. Now you can open the circular access, but still expect some water to escape so lay a few dirty towels on the floor.
The circular access door usually unscrews counter-clockwise and attached to the rear of it is often a debris trap. Clean the trap and then clear any debris from the pump which will now be visible. Most of the time the blockage will be socks, tights or underwear. Once you're sure that it's all clear, check the pump impeller vanes (should be visible) to ensure that they're not damaged and try turning the impeller by hand (should be easy if the pump is now OK). Now just refit everything and turn the machine back on.
If the symptoms continue, or if there is no access door to the pump, then you'll need assistance. Turn the machine off again, and then pull it forwards a couple of feet. Tilt the machine backwards and securely prop it up so that there's no risk of it falling down nor of sliding further back or forward. If you have already tried the first repair method then you'll already know where the pump is located, but if not then it's easy to identify. There will be two tubes connected: the outlet goes out of the rear of the machine to the drain and the inlet is usually a flexible rubber bellows type of tube and goes from the pump to the drum. Give the second tube a good squeeze all along its length to feel for any obstructions. If there are any then disconnect the tube from the top of the pump and remove the blockage (if the machine is still full of water then get ready with a large bucket and expect to get wet). The hose clip will usually be a spring clip which you'll need pliers to remove and refit: squeeze the tangs together to loosen the clip and release them to tighten it. If there are no blockages then check the outlet tube. As it's normally of semi rigid flexible plastic it's harder to find blockages in, so I tend to just remove the end from the pump and poke inside with a piece of coathanger wire.
If after all this you find nothing, then the the pump is the chief suspect. On European machines it's usually an integrated motor and pump assembly which has to be replaced as a single unit, but on the few American and Australian models I've repaired the pump and motor may be separate and connected via a flexible driveshaft. If the latter, disconnect the shaft and temporarily reconnect the power supply. If the motor now runs the pump needs replacing and if not it's the motor.
I hope this has been of assistance to you and that you manage to quickly fix your problem.
Posted on Oct 02, 2010
My ge front load washer fills then stops during cycle and does nothing else. It spins in the beginning then will not drain at the end
It sounds like the drain pump itself is damaged--the important clue was the humming noise. It could be bound up mechanically or the impeller could be damaged and just vibrating instead of spinning. The part number for the drain pump is WH23X10026. The fact that the pump was humming tells me that the 120v supply is being turned on by the main control board and that the wiring is good all the way to the pump. When I service customers, I try to save the pump if possible in clog cases. Most of the time, they aren't damaged from a simple clog. But, occasionally, the impeller cracks, or the nylon blade gets loose on the shaft, or the motor windings have defects from heat, etc.
Jul 23, 2015 | GE Energy Star WCVH6260F Front Load Washer
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
770 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
