Question about Celestron NexStar 114GT (269 x 114mm) Telescope
Motor for elevation does not run. The traverse motor will run for a few seconds then quits and won't restart. I've replaced batteries repeatedly. The unit is about 10 years old but has only been used once due to eye issues. It has been kept out of the dust and all electrical battery contacts are in new condition. The unit is a Nexstar 114 GT.
  • 3,186 Answers
This old scope may not be worth repairing-- contact Celestron directly here:
http://www.celestron.com/c3/page.php?PageID=37
Posted on Oct 02, 2010
How do I calibrate elevation grade for treadmill?
Hey there, sorry to hear you're having an issue with your elevation motor. I would be happy to help you solve the problem.
Since you already installed your motor you can go straight into diagnostic mode.
To get into Diagnostic Mode on your L8
Make sure to turn off your treadmill.
-ET's - Press Menu and Start at the same time
-CT's - Press Manual (or Display^) and Start at the same time
-All other L SERIES mills - Press Display (or display and Start at the same time
SideNote-
-*CT's that were manufactured after 09/2003 - Press Display and start at the same time.
Few things you want to do, if you haven't already.
A. Align the motor with the clevis mount and install the motor mounting pin.
B. Insert hitch pin.
C. Reconnect the elevation harness to the lower board
D. Set the lowest limit switch by holding the UP elevation button for 5 seconds. Then press and hold the DN elevation button one more time to make sure you only hear a click.
E. For L7/L8 machines; Thread the elevation nut to where its flush with the threads on the "worm' shaft.
F. Mount the elevation nut to the leg assembly by lining up the holes on the leg assembly. You may have to move the leg assembly so that the holes on the elevation nut line up. Then slide the two elevation pins through the elevation assembly and into the elevation nut. then secure the pins with the 2 set screws.
To calibrate your potentiometer you can try to adjust while it is installed but for best results you must calibrate it before its in your motor housing.
G. Calibrate the elevation potentiometer and to do so you must;
1st: Visually confirm treadmill is leveled. (0% grade)
2nd: Adjust the settings as follows;
All L SERIES millls should read 0.0
3rd: If the setting is incorrect, follow these steps.
Step 1: Turn the post of the potentiometer all the way
CLOCKWISE.
Step 2: SLOWLY turn the potentiometer COUNTER
CLOCKWISE until the setting is correct.
H. Carefully install potentiometer into the motor housing
*NOTE: The setting may vary when inserting the potentiometer
into the motor. As long as the change is minimal, fine
adjustment can be achieved by rotating the meter
while inside the elevation motor.
I. Press OFF to turn treadmill off. Then restart the machine in manual mode to TEST elevation after resetting your potentiometer. As long as the change is minimal, fine adjustment can be achieved by rotating the potentiometer while inside the elevation motor.
For more Diagnostic features and possibly further detail, I will be attaching a Link to your machines service manual. I hope this helps, always hear to help. SportSmith.
http://www.sportsmith.net/images/product_support/landice/Manuals/Service/P0472050%20L%20Series%20Service%20Manual.pdf
Apr 20, 2015 | Landice L8 LTD Cardio Trainer Treadmill
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
I have a Horizon QuantumCS 11 HRC Pacer Treadmill and I am getting E7 flashing when turned on,belt moves for seconds and then stops
please follow the steps and fix it. God bless you
2)Alternative:
Nov 15, 2012 | Exercise & Fitness
What does E7 mean on Lifespan TR4000i?
see the 2 alternatives that the error code 7 means:
2)Alternative:
However RUN the software calibration for diagnostic, troubleshooting and Fix it.
God bless you
Sep 29, 2012 | LifeSpan Fitness TR4000i Folding Treadmill
Motor won't engage. I turn the throttle and get a clicking sound, but nothing happens. We've charged the battery for about 4-6 hours, but the light stays red, never turns green. Help?!!
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
Jul 08, 2012 | Electric Razor Pocket Rocket Ride-on...
Nordyne Split System Blower Won't Start
It's the fan motor. A relay problem would cause the motor not to run at all.
May 08, 2017 | Heating & Cooling
2009 Traverse, the engine cooling fan remains on for @ 1 minute after switching off the engine and removing the key from ignition. Is this normal and if not what is the problem. Thanks.
That is absolutly normal, the fan is designed to run at a certain temperature not just when the motor is running. On short trips or cool weather the fan won't run at all till needed.
May 30, 2011 | 2009 Chevrolet Traverse
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
Dewalt dc 988 cordless drill
We.ve the same problem with those Chinese batteries and find that this problem is quite wide spread with many brands using these batteries. I'm speaking from experience with our battery factories. No quality control!
May 04, 2008 | Dewalt 18 Volt Compact Drill Kit
Celestron NexStar 114GT (269 x 114mm) Telescope Logo
234 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
