Question about Tappan Microwave Ovens
Works but don't heat the food - Tappan Microwave Ovens
    President:
  • 2,777 Answers
This is definitely a major issue, and I see it quite a bit. The first thing I would test is a secondary interlock switch
If the switch is fine then the question is: does your microwave make any unusual noise?
If it does then most likely the problem is a shorted rectifier or a shorted magnetron tube If there is a continuity across the rectifier terminals (using a regular meter) - it has to be replaced.
If there is a continuity between any of the magnetron tube terminals and the body of the magnetron tube - it has to be replaced.
In case if the high voltage transformer shorted out, in most cases it should produce an electrical burning smell and a smoke.
But your best bet is to take it to a professional, or just replace the microwave. It is a major repair in any case.
Thanks Tim
Posted on Oct 02, 2010
Sharp 1200w microwave seems to be tripping lightly (can hear clicking noises)and cause heating to be irregular
Clean the food off the inside top of the microwave Now,Or that noise you are hear will stop along with the microwave. The food gets on the Formica Squire which is how the micro waves heat your food. 1st unplug the Microwave then spray the inside of the unit with something like Fantastic or something strong and use glove so you don't burn you hand,Also if you have a scrub brush use it,And clean all the soap out and raise very well.
May 02, 2012 | Sharp Microwave Ovens
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
The microwave does not heat up the food but everything works except the fact that it don't heat up the food
Hi!
The most common cause of the problem you described is a burned fuse. It is normally located inside the case, directly on a wire leading from the transformator to the magnetron. If you are not sure about those parts, please get a professional to fix the issue.
Aug 20, 2011 | Samsung SMH9187ST Microwave Oven
My 7 years old dacor pmor30s microwave oven sometimes works ok, but sometimes it does not heat the food. I don't know why. Do you have any idea?
The most probable cause would be a problem with one of the door switches. When it is not working shake the door up and down and hit "start" again. If that made it work, you would need to test the switches for proper operation.
Aug 09, 2011 | Microwave Ovens
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. We used it about an...
Usually when it doesn't het there is a problem with either the magnetron or one of the power tranistors. You would have to get a shop to tell you what the problem is as it can be a few things. If you have warrenty either maytags or from the store just find out from the store/maytag where the repair depot is. They will either repair or replace it. If no warrenty then don;t do anything without getting an estimate. It may be just as cheap to buy a new microwave.
Aug 12, 2010 | Maytag MMC5000 Microwave Oven
Microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
Jun 14, 2009 | Magic Chef CMV1000B Microwave Oven
Sharp R-202EW microwave croaking- roller needs replacing?
You could remove the new turntable support but without replacing it (part # FROLPA101WRKZ) you just won't get even heating.
One option might be to remove the support, place in another (larger) glass tray or other microwave safe plate upside-down, then put the existing tray on top of that.
That will raise the food up. Then be sure you don;t place the food in the center. It will heat better if it's a little left of center.
Nov 04, 2008 | Sharp R-202EW Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
