Question about Siemens 24 in. SE53200 Built-In Dishwasher
My Siemens dishwasher takes 4+ hours to complete a cycle. The inlet water supply has been always COLD, which means that the dishwasher always managed to heat the water properly. What could be happening now?
2 Suggested Answers
SOURCE: siemens dishwasher sl33a002uc takes 4
Take the control board out, open it up, and resolder the heater relay or replace the control. It may be under the recall and you can get a new control replaced for free.
Posted on May 18, 2011
My whirlpool gold series dishwasher will not stop running through cycles unless i open the door. It will just continue to run for hours. Any relatively easy fixes before i call backup?
Some dishwashers can run for 4 hours or more normally depending on the options you choose. What do you mean by it runs through cycles is it always changing cycles by itself or is it just the cycle you pick just keeps on going, have you tried a quick wash or 1 hour wash does it do it then? is you hot water hot enough? if not it makes the unit run longer because it has to heat the water up. always run the hot water at the sink to bring hot water up from the water heater to the sing so the dishwasher fills with hot water and not cold.
Dec 28, 2016 | Whirlpool Dishwashers
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
How long does a normal cycle take on the following Kitchenaid diswasher. KUD102CRWH1 Mine takes hours. Is this normal?
If the normal cycle is taken hours then the water temperature is not correct. If you have inlet hot water connection, then check the water temperature. If using cold water then the thermostat or heater in the dishwasher is faulty.
Look for items 7 and 12 in this diagram.
Oct 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Siemens dishwasher sl33a002uc takes 4 to 5 hours to complete a cycle - what is wrong?
Feb 07, 2011 | Siemens 24 in. SL34A006UC Built-in...
My dishdraw takes twice as lond as it should to complete a cycle
It would help if you provided the dishwasher make and full model no.
Usually the dishwasher can take longer if the water temperature is not correct. If you are using hot water connection then make sure the inlet water temperature is at the correct temperature.
If you are using cold water connection then check if your dishwasher is designed for cold water inlet. The dishwasher heater could be playing up.
Please rate this solution to help fixya serve you better in future.
Sep 26, 2010 | Dishwashers
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Our dishwasher goes through the cycle and finishes fine without water in the bottom. Then within a couple hours, water comes up and sits at the bottom of the dishwasher. Handyman could not figure out...
Hello Sandra, Welcome to Fixya ! You've come to the right place. The problem you're experiencing sounds like (unfortunately) a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid to late 90's. Unfortunately I've seen some pretty serious damage over the years in extreme cases when left unchecked for several days...or longer. Here's a tip on how you may be able to confirm or dismiss this possible problem by yourself. When the dishwasher complete's a wash cycle turn off the water supply line to the machine ( usually under the sink in the cabinet ) If the unit doesn't fill as it had been, it's probably a faulty water inlet valve. Having said all this, you may want to call in a pro if you aren't completely comfortable doing that. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic.com, apwagner.com etc. Supply them with your model AND serial number to be sure you get the correct valve. You can also do a search for part # 1105846 at repairclinic ( that is their part # not B/S/H/ ) you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch/Siemens, just turn off the power, the water, access is gained through the kick plate/toe panel below the door. The valve will be on the left and involves only removing 2 screws, the water line in & out and 2 wires which go on either way...they aren't polarity specific. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Good luck. Macmarkus :)
Jun 10, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
SIEMENS SE64630GB NOT TAKING IN WATER
I know sounds stupid, but I must ask: Are the water supply valves turned on? Is the water supply pressure good?
A pump usually isn't found on the inlet side. Most such appliances have sediment screens located in the water inlet connections. These will sometimes get blocked with sediment such as lime, for example. Otherwise, you may have a defective controller or defective solenoid. Most units have two solenoids (hot & cold). The solenoids are located at the water inlet hookup (the screen is usually a part of the solenoid). When the washer is started, a metallic click should be heard from the solenoids. Beyond checking the screens and water valves, a repairman should be called in, unless you're skilled with a voltmeter, electrical troubleshooting, and appliance disassembly.
BTW- is this a new installation or has the unit been in service for awhile?
Good luck.
Apr 13, 2008 | Siemens 24 in. SE64A630GB Built-In...
No water coming into dishwasher
My Frigidaire runs for 4 hours. It takes 4 hours to complete a cycle.model-FDB8345
Nov 03, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Siemens 24 in. SE53200 Built-In Dishwasher Logo
67 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
