Question about Sony Cyber-shot DSC-H5 Digital Camera
Zoom stopped working. Error message: Turn the power off and on again.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 10, 2010
"Turn the power off and on again" error message
the lens zoom ring is jammed, or broken , if the zoom looks broken just try to staighten it, you will hear a breaking kick noise, but it might work unless it is already broken which might require a professional service.
Dec 09, 2013 | Sony Cyber-shot W290 Digital Camera
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to www.unitedcamera.com
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
My cybershot DSC W270 zoom will only go up to 1.6x then it stops and an error message appears telling me to turn the camera off and then on again but this does not solve the problem. I havn't dropped the...
If turning the power off and on again doesn't solve the problem, the Sonyusa.com's eSupport website says to send it in for service.
The camera was listed as sold in Canada and Latin America,
and the following service locator weblink may help you:
http://www.sony.ca/html/locator/locator.html
Aug 17, 2010 | Sony Cameras
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Zoom will not work at all get error turn off camera
The unit attempts to get the lens into a known position when the power is first turned on. If this fails to complete properly, the message you see will be displayed. It is hoped that the power off/on/reset will cure the problem. Since the message appears all the time, the zoom/fucus motor is either stuck or the mechanism is jammed. Some people say to gnetly tap the side of the unit while the power-on sequence is running. This may be enough to release the gearing. Short of that working, I would recommend that you take this to a service center. They will clean and relube the gears inside.
Dan
Jun 18, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
The lense will not zoom
Your camera has a zoom failure that can not reset by pushing menu buttons or else. Ask your local Sony repaircenter.
Regards,
Rob NL
Apr 24, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Sony Cyber-shot DSC-H5 Digital Camera Logo
32 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
