Question about Lomo BRAND Fisheye 2 Camera UK seller lomography 35mm Film Camera
I put the film in my camera backwards(with the tail of the film facing to the left) and i cant get it back out. when i tried pulling up on the rewinder thing part of it snapped off
    Brigadier General:
  • 3,006 Answers
If it was just the folding lever part of the rewinder which has broken off then you'll need to use a flat bladed screwdriver or the tip of a knife to lever up the rewind knob sufficiently to pull it up and open the camera.
If you've broken any more than that, then your camera is unrepairable. Spare parts are not available for your camera as it's only designed to last for six rolls of film. Even regular Lomo and Holga models are only intended to last for a maximum of twelve films.
Posted on Oct 02, 2010
Camera wont let me rewind film
Get a heavy coat and zip it shut, take it and the camera into the darkest room in your home, put the camera in the coat and reach through the sleeves backwards, Grab the camera and open it and take out the film, wind it back into the cannisteer by hand.
Dec 13, 2014 | Photography
I need help loading film on to a Canon AZ-2900R Automatic
It is not possible for me to find a manual, but the camera looks like my my EOS5oo (film camera, not the digital one)
I still have some film camera's from Canon and the way to put in the film is the same in almost every one, so I give it a try. Make sure you have the correct batteries in the camera. You can check by turning the mode dial to any position other than L and look on the display. If the battery symbol is flashing, it is too low. Turn the mode dial to the L. Open the camera, then put the roll in the left hand space and while holding the spool in place pull out enough film (one to 2 inch) to reach the orange point on the right hand side. Then close the camera.
If you pulled out more film, please put it back in the spool by turning the knob.
As soon as the camera is closed it will spool the film to the starting point. A little spool symbol and the ISO will be visible on the display. When the spool is blinking something went wrong and you have to insert again.
I'm not sure if your camera detects the correct ISO, but if not you have to correct that your self. I don't know how to do that.
I think there is a category for analog cameras too. This one was in digital cameras. Success
Jan 04, 2014 | Cameras
How do you put the film in in a olympus superzoom 105g
Open the back, gently blow out any dust that might have gotten in there. Load film in the shade. Take the film cassette out of the plastic container and insert it with the protruding piece on the bottom into the left side of the film compartment. Gently pull the film out to the right about 3-4 inches. Try to keep the film flat across the shutter opening but Be Careful you don't touch the Shutter Blades! Feed the film under the take-up spindle and through the vertical slot and hook the film into a sprocket. Push down the shutter release button and advance the film a couple times. Close the camera back securely. You are ready to go! Good luck
Aug 03, 2009 | Photography
Can't advance film, press shutter, no result
Do you have film in the camera? If so, is it an old film or you have just loaded it?
If it's an old film, could it be at the end of the roll - to check this, 'lightly' turn the rewind lever backwards and forwards. As the camera is pointing away from you, turning the rewind knob clockwise will normally rewind the film (don't press the rewind button in, we don't actually want to rewind the film yet), turning the knob clockwise should be tight and a firm stop, if the film is at the end, you will feel the same tight firm stop if you turn it counter-clockwise. Don't turn the rewind knob backwards (counter-clockwise) too hard, you'll unscrew it and it may fall apart. If turning it backwards rolls freely in a full circle, then you have film left.
Another option is that, since it's been so long since you used it, the loading of the film may have gone amis and sometimes the cassette will flip backwards, jamming the film in place so it wont advance - if you have loaded the film and not taken any pics or have not been able to advance it at all, it should be safe to open the back as the film will be in it's original loading position, if you have left the film in it from some time and don't know what stage it's up to it may be best to take it to a camera store where they will have a "Black Bag" to put the camera in and manually open and unload the film. Make sure you get an experienced person - some pimply-face teen that's never used a film camera can easily put their fingers through the shutter while it's in the black bag - I've seen it plenty of times.
OK, that's enough to get started, did this work or do we need to try more options?
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
Loading film into the vivitar camera binouclurs
you have to pull up on the film rewind knob(pretty hard) and the back of the camera pops open. on the left side is where the film goes attach the piece of film to the film take up spool.
Jan 12, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
Idk how to open the back to put my film in i have a vivitarv3800n
If it is the camera posted in the picture, try pulling up the tab on the film winder on the left side on top, after the tab is out pull the whole dial up and the door should pop open.
Jan 10, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Jul 21, 2008 | Kodak Vivitar KV270 Film Camera
Cant open camera to get film out
Hey stupid 01,
To open your camera back you need to pull up on the rewind lever knob (on the left side of the camera with the lens pointing away from you), and the camera back should pop open. Before you do this make sure your film has been rewound back into the film canister or you will ruin your images.
Sincerely,
Allan
Go Ahead. Use Us.
May 11, 2008 | Cameras
Vivitar
be sure that nothing film inside the camera , open back side of camera by pulling spinning knob , put film spool on left side and at the right side insert the film strip on diagonal small hook, turn the spool rachet turning left side then click shutter twice while holding the spinning spool left side , then close the cover , tightened the spinning spool little bit then test shoot.
Dec 25, 2007 | Photography
Lomo BRAND  Fisheye 2 Camera UK seller lomography 35mm Film Camera Logo
152 people viewed this question
Top Lomo Photography Experts
Are you a Lomo Photography Expert? Answer questions, earn points and help others
