Question edited for clarity and correct model name tempura to Tempra.
It is one of the pull chains. If it has two chains, one if Fan On/Off and three speeds and the other chain is Reverse Direction. If it has a third chain, that is Light On/Off.
Product description
Casa Vieja Tempra ceiling fan in a oil-rubbed bronze finish. 3-speed reversible fan. It has 5 oil-rubbed bronze finish blades that span 52" with a 12 degree blade pitch. Opal glass light kit included two 13 watt CFL bulbs. Cap included for non light kit usage. Comes standard with a 4" downrod. Dual mounting hanging system allows for it to be hung from a downrod or flush with the ceiling. - Oil-rubbed bronze finish 3-speed motor; Lifetime motor warranty. - Five matching blades; opal glass light kit includes two 13 watt CFL bulbs. - Pull chain operation. - 52" blade span, 12 degree blade pitch. - 4" downrod included. - 153x12mm motor size. - Fan height 11.6" ceiling to blade (with 4" downrod). - Fan height 16.6" from ceiling to bottom of light kit (with 4" downrod). ..
1. Check the wattage of the bulb. you may have fitted a higher, dense filament bulb.
2. The Switch - if you have a dial type knob on the switch, turn that higher to see if the light brightens.
Bent??? Or just LOOSE? If it's loose, it can be tightened easily (it probably requires just a screwdriver). If it's truly BENT, it probably can't be fixed - those brackets aren't usually available (they very seldom get damaged), and they're cast so they cannot be straightened. Even if they COULD be straightened, it'd be very difficult to get the bend exactly correct (which is why they're cast instead).
I believe this fan is sold by a private lable on the internet. You probably need a new receiver which you'll have to get from the store that sales that brand.Google it.
I cant find it either
