Question about Kenmore 63942 Dryer
Dryer tub does not turn - Kenmore 63942 Dryer
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 03, 2010
Testimonial: "Thanks very much---that'll fix my problem!"
Dryer
You need to check the belt around the outside of the tub that turns the tub, the tention pully and the motor. is the belt broke? loose? motor turning?
Aug 17, 2012 | Dryers
The dryer in my trailor tub wont turn I have Heat but the tub wont spin.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 08, 2011 | Dryers
Dryer hummes when you turn it on but does not rotate
This don't sound good most likely the motor is bad . OK first unplug the dryer take the belt off the motor now plug the dryer back in hit the start switch does the motor turn NOW??? If not its the motor. IF the motor does turn??? could be a weak motor OR Bad bearing in the Back of the tub.
Rotate the TUB by Hand UNPLUG THE DRYER FIRST. IF the tub Rotate freely I would say you
Have a bad Motor But if the tub is very hard to turn now your looking at a bad Bearing
GOOD LUCK HOPE THIS HELPS
Nov 21, 2010 | LG DLE5977 Electric Dryer
Dryer smells like something is burning and making a slight humming sound
check tub bearings and/or rollers or for anything that could impede the turning of the tub. Sounds like something is stopping the tub enough
to make the drive motor turn on the belt causing it to burn and smell.
If you fix the problem with the tub be sure and change the belt
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Turn on it only hums
most likely a bad motor or something stopping the motor like a missing sock or cloth jammed into blower area..open door and spin tub while holding in door switch. a second person may be needed to turn on dryer at panel. if tub starts while turning tub by hand. you'll need a new motor. if still does not start..check for obstruction..no obstruction, bad motor
May 15, 2010 | Dryers
Replace dryer belt
take off back of dryer....belt goes around tub and a pully on the motor....its fairly easy...when you get on there youll see...just make sure the tub is alligned correctly when you get it back together...turn the tub manually a cfew times before turning on and unplug before repairing......thanks and have a great day
Nov 08, 2009 | Amana NDE2330AY Electric Dryer
Bosch dryer making rumbling /grinding noises low frequency
you might want check the rollers that tub rides on they are in the front lower part of the dryer, or the belt that turns the tub.
Jun 23, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer tub turns but there is no heat
I have a frigidaire crown series dryer.the tub turns,timer works but there is no heat coming out.
Jun 23, 2009 | Whirlpool Dryers
Dryer is heating but tub is not turning
Most likely a broken belt. If you want to pursue, let me know.
Apr 29, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 63942 Dryer Logo
187 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
