Question about Weber Genesis E-320 Propane Grill
The tube that attaches the regulator to the grill was burned by the grill pan, but to replace it I need to remove it from the grill. The attachment point does not seem to want to unscrew - how do I remove this from the grill?
  • 1,040 Answers
On gas related attachments, the threads unscrew the opposite direction. So it should unscrew clockwise, instead of counter-clockwise.
Jim
Posted on Oct 02, 2010
How to replace the oil pan gasket in a f150 1988 truck
Hi there:
  1. Drain the cooling system.
CAUTIONWhen draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Remove the bolts attaching the fan shroud to the radiator and position the shroud over the fan.
  2. Remove the upper intake manifold and throttle body (see Fuel System ).
  3. Remove the nuts and lockwashers attaching the engine support insulators to the chassis bracket.
  4. If equipped with an automatic transmission, disconnect the oil cooler line at the left side of the radiator.
  5. Remove the exhaust system.
  6. Raise the engine and place wood blocks under the engine supports.
  7. Drain the crankcase.
CAUTIONThe EPA warns that prolonged contact with used engine oil may cause a number of skin disorders, including cancer! You should make every effort to minimize your exposure to used engine oil. Protective gloves should be worn when changing the oil. Wash your hands and any other exposed skin areas as soon as possible after exposure to used engine oil. Soap and water, or waterless hand cleaner should be used.
  1. Support the transmission with a floor jack and remove the transmission crossmember.
  2. Remove the oil pan attaching bolts and lower the oil pan onto the crossmember.
  3. Remove the two bolts attaching the oil pump pickup tube to the oil pump. Remove the nut attaching the oil pump pickup tube to the No. 3 main bearing cap stud. Lower the pickup tube and screen into the oil pan.
  4. Remove the oil pan from the vehicle.
To install:
  1. Clean the oil pan, inlet tube and gasket surfaces. Inspect the gasket sealing surface for damages and distortion due to overtightening of the bolts. Repair and straighten as required.
  2. Position a new oil pan gasket and seal to the cylinder block.
  3. Position the oil pick-up tube and screen to the oil pump and install the lower attaching bolt and gasket loosely. Install nut attaching to number 3 main bearing cap stud.
  4. Place the oil pan on the crossmember. Install the upper pick-up tube bolt. Tighten the pick-up tube bolts.
  5. Position the oil pan to the cylinder block and install the attaching bolts. Tighten to 10-12 ft. lbs. (13-16 Nm).
  6. Install the transmission crossmember.
  7. Raise the engine and remove the blocks under the engine supports. Bolt the engine to the supports.
  8. Install the exhaust system.
  9. If equipped with an automatic transmission, connect the oil cooler line at the left side of the radiator.
  10. Install the nuts and lockwashers attaching the engine support insulators to the chassis bracket.
  11. Install the upper intake manifold and throttle body (see Fuel System ).
  12. Install the fan shroud.
  13. Fill the crankcase.
  14. Fill and bleed the cooling system.
Fig.: 5.0L and 5.8L engine oil pan gaskets and seals
1987 5.8L Engine With 4-Bbl. Carburetor
  1. Remove the oil dipstick (on pan entry models only).
  2. Remove the bolts attaching the fan shroud to the radiator and position the shroud over the fan.
  5. Raise the engine and place wood blocks under the engine supports.
  6. Drain the crankcase.
  1. Remove the oil pan attaching bolts and lower the oil pan onto the crossmember.
  2. Remove the two bolts attaching the oil pump pickup tube to the oil pump. Remove nut attaching oil pump pickup tube to the number 3 main bearing cap stud. Lower the pick-up tube and screen into the oil pan.
  3. Remove the oil pan from the vehicle.
  4. Clean oil pan, inlet tube and gasket surfaces. Inspect the gasket sealing surface for damages and distortion due to overtightening of the bolts. Repair and straighten as required.
  5. Position a new oil pan gasket and seal to the cylinder block.
  6. Position the oil pick-up tube and screen to the oil pump and install the lower attaching bolt and gasket loosely. Install nut attaching to number 3 main bearing cap stud.
  7. Place the oil pan on the crossmember. Install the upper pick-up tube bolt. Tighten the pick-up tube bolts.
  8. Position the oil pan to the cylinder block and install the attaching bolts. Tighten to 10-12 ft. lbs. (13-16 Nm).
Hope this helps, also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Apr 16, 2012 | Ford F-150 Cars & Trucks
Tip
Cleaning your coils.
<span>Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.<span> </span><span> </span></SPAN><br> <span>Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.</SPAN><br> <span>Reinstall the pan and the grill.</SPAN><br> <span>Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.</SPAN><br> <span>If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.</SPAN><br> <span>If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.</SPAN>
on Feb 23, 2011 | Refrigerators
Frigidaire Gallery FRS24XGCW Regrigerator is not cooling. The freezer side is about the temp of the normal refrigerator side.
Mar 01, 2011 | Frigidaire Refrigerators
Our side-by-side built-in refrigerator is recently not cooling enough though the freezer still works well. It is 15 years old, but I'm wondering if it can be fixed instead of having to replace it. Are...
if i can help let me know.
Feb 25, 2011 | KitchenAid Refrigerators
Freezer is freezing, but ice box is not cold. Told to clean fan. Where is the fan located?
Feb 25, 2011 | Refrigerators
There is a drain plug in the bottom of freezer. How do you defrost and not have water on floor. Is there an attachment hose of some kind? I do not have a manual.
You did not supply a make or model. Typically there is a drain in the freezer with a drain tube to a drain pan below the machine. If you take the bottom grille you should be able to see the drip pan and the drain tube. The drain tube is a flexible tube about 1/4" diameter you might be able to attach an extension using a barbed fitting that you can get a a home depot or lowes.
Aug 22, 2010 | Freezers
The hose to the regulator caught fire and burnt off. I bought a regulator with hose, but it doesn't seem to attach.
Keep in mind that LPG valve threads are reversed (left to tighten and right to loosen). In addition tank valve and regulator fittings change causing confusion and problems.
Apr 25, 2010 | Fiesta Blue Ember Gas Grill
Propane flame is not blue but too high
A yellow or orange flame means (1) too much fuel, or (2) not enough air. Make sure the air ports where the regulator attaches are clear and that spiders or bugs haven't built a nest in the burner tube. If that's all clear, it's likely that the propane regulator has failed and is allowing too much fuel to enter the burner tube. The regulators are inexpensive and are not repairable; get a replacement unit.
Oct 08, 2009 | Weber Gas Go-Anywhere Grill
Attaching the regulator
The regulator is inserted into the end of the burner tube, which protrudes a couple of inches from the end of the lower grill tub, under one of the carrying handles. It is held in place by a "C"-shaped spring wire clip and can rotate freely. One can attach a disposable propane cylinder for portability or a hose from a bulk tank for back yard or base camp use. See photo below.
Jul 06, 2009 | Weber Gas Go-Anywhere Grill
Cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
Apr 11, 2009 | Coleman Roadtrip Grill LXE 9949-750
Weber Genesis E-320  Propane Grill Logo
111 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
paulcarew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
