Question about Goodman CLQ36AR49 Air Conditioner
Ac leaks my ac leaks out the front.the drain is not clogged. no sure what to do mark
  • 20 Answers
Chek if there is a corect downhill pitch on the drain if notcorect the pitch or get a condensation pump
Posted on May 27, 2008
08GMC Acadia leaking water on the floor when ac is on. We took the car into the dealership & they cleaned out drain lines to make sure there is no clog. Still is happening. Any other reason for this?
The AC box that contains the Evaporator core is not sealed properly, or the drain is clogged again. Check the drain again, it exits under the car on passenger side base of engine bulkhead.
Aug 30, 2016 | 2008 GMC Acadia
Water coming out of front of unit, thru vents leaking on floor
Darlene, if this is a window or thru the wall unit, the leaking is usually caused by two things:
1. The drain pan under the unit has a drain hole (in the rear outside part of the unit) that is clogged.
2. The AC unit is not tilted down at the rear 1/4" to 1/2", so that water will drain to the outside drain hole.
Be prudent when you look for the drain hole in the drain pan. As the clog can blend in with the drain hole, making it difficult to see.
Hope this helped you troubleshoot and solve the problem.
Jul 18, 2011 | Haier Heating & Cooling
Fedders AC leaking water from front, older model was in storage. Cant find the manual to make sure it's installed proper, or see if we need to clean somehting out. It leaks when it's running, then...
The unit needs to be tilted down 1/4/" to 1/2" on the outside of the window. Also check the drain pan's drain hole, under the unit (outside the window) for clogs. Doing all of this should solve the problem.
Jul 11, 2011 | Fedders AEQ07FBG Air Conditioner
Water on floor passenger side after it rains and after air has been running 2000 grand prix
Ac hose leak?
leaking heater core?
Hint: it leaks when it RAINS
If it were related to the heater core or the AC drain, it would be leaking when it is not raining also, so those diagnoses are not logical.
The grand prix has a long history of floor leaks from seal failures around the air intake under the windshield cowling, where RAIN water runs in.
May 04, 2011 | 2000 Pontiac Grand Prix
Water leaking on passenger side rug,how can i fix the problem, is it the AC tubing clogged up?
Yes, you have a drain line on the AC unit in front of the passenger seat, it comes through the fire wall and it gets clogged easily, find it, clear it and no more wet floor. It will flood the floor if you don't. Check it out.
Jul 29, 2010 | Dodge Stratus Cars & Trucks
I am having problems with A/C condensation leaking inside with flooding the front and back floor of Car
check your drain hose for blockage, if it's clogged up the condensation will leak into the floor
Jul 19, 2010 | 2004 Mazda RX-8
How to stop a leak
the water leak is not a big concern -other than the mess it causes, but as to the AC's operational status it is supposed to draw water/humidity from the 'cooling space' so - it's still doing it's job (I'm assuming it's cooling too).
As to the water - I would check the drain to be sure it's not clogged up - which is usually the problem. If the drain is clear and the AC is draining (to the outside) properly - I would then check and make sure the AC is tilted backwards out the window.
good luck!
Jul 13, 2010 | Carrier BCA101R Air Conditioner
I have a Amcoraire that leak water during running AC
blow in to the drain from outside also check and make sure the filters are clean
Jun 07, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
LG 18000 ac leaks water in the front of unit indoors.
the drain pan is either clogged or the unit is not mounted properly. If the drain pan is clogged simply clean it and the problem goes away. In the case of the unit mounting, check the angle of the unit and the drain pan inside, if it tilted to the front even just a little then water would leak. the drain pan should lean toward the drain and away from the front.
I hope this helps.
Jun 05, 2009 | LG LS-K1830CL Cool Mini Split Air...
Goodman CLQ36AR49 Air Conditioner Logo
91 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
