Question about Moen Home
How to fix a leaking Moen Adler CA84500 faucet,
  • 297 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
  • 44 Answers
SOURCE: I cant stop my Moen single lever kitchen faucet
1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
Reassemble and enjoy.
2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Posted on Sep 09, 2009
Testimonial: "this will give me something to work on. thanks"
  • 127 Answers
SOURCE: the cartrige inside my moen faucet leaks
moens website. they have parts break down and diagrams
Posted on Dec 05, 2009
1stBSP
  • 52 Answers
SOURCE: I have a Moen Single Handle kitchen faucet, it's
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Posted on Apr 06, 2010
  • 94 Answers
SOURCE: New MOEN 1222 cartridge leaks
remove it and carefully inspect it, you might have scuff'd up the rubber's on the cartridge when you inserted new one.clean out,look in hous'ing for any foriegn mat.etc .you may need another new cart.
Posted on Apr 24, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Dripping
    you need to get a replacement cartridge moen Faucets have a tendancy to go bad you can lok up the part number at moen .com most faucets have a warranty if not the will ship a new one in about 3-5 days
    Apr 11, 2013 | Moen L82691 Adler Single-Handle Posi-Temp...
    How to install moen adler shower faucet
    Doug-
    Moen makes six models of the Adler shower faucet. You can find the specific installation manual for the faucet you have on their website, at LINK. Select the unit you have and open the PDF of the manual on the following page.
    Regards,
    DIYpro
    Jun 05, 2011 | Moen Home
    Installed a new moen adler tub faucet with shower diverter. When you turn on the shower water continues to come out of the tub faucet. Is there an adjustment or is it just the way it is??
    Our Moen always dribbled a little since the diverter is metal-to-metal and doesn't really have any seal. The loss shouldn't be a stream though.
    Nov 11, 2010 | Moen & One Handle Tub & Shower Faucet
    Disconnect/reconnect drain part of MOEN (Adler) bathroom faucet CAL84502. I'm changing the entire basin and reinstalling the MOEN faucet system but can't find my original installation instructions.
    Should be 3 wing pipe nuts. One at basin base, and one on each end of you elbow. They should all turn counter-clockwise to remove. The one on the basin base likely and commonly has pipe thread tape on it.
    Aug 08, 2010 | Moen Home
    I installed a Moen Adler faucet. It will not shut
    You may just have a piece of sediment lodged in the cartridge from when the water was shut off during installation. Carefully remove the cartridge and turn the water on to flush out any obstructions. re install the cartridge and test.
    Feb 18, 2010 | Moen & One Handle Tub & Shower Faucet
    We are trying to replace our Moen Adler Faucet and we need to know how to remove it.
    first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
    Jan 11, 2010 | Porter Cable Moen Legend, Single-Handle...
    Home Logo
    590 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
