Question about Toro Lawn Mower With Toro Power Tools
I have a Toro Personal Pace Recycler mower with a 6.0 hp GTS engine. I need help on replacing the pull cord.
    Problem Solver:
  • 5 Answers
It's not that hard. I've never done it on my Toro GTS 5.0, but I have done it on a Briggs and it's pretty much the same. Start by removing the 10mm bolts around the perimeter of the engine shroud. DON'T remove the 4 top bolts on the recoil housing. You might have to remove the fuel tank first. Drain it, then loosen the 2 8mm screws and lift it straight up. No need to disconnect the fuel line, just set the tank aside. After removing the 10mm bolts, the shroud should lift right off. Flip it over and you will see the recoil pulley. Remove any leftover cord from the pulley. Now you need to wind the pulley against the spring in the direction it goes when you pull the cord. It might wind 2 or 3 revolutions but don't overdo it. Now you will need some sort of clamp to hold the pulley in place as you line up the slot in the pulley with the opening where the handle goes. Next, feed the new cord through the opening and into the pulley and tie a knot to keep it from slipping out. Carefully release the clamp and let the pulley slowly wind the new cord onto itself. Finally, attach the handle on the other end of the cord and test it. If you can pull the handle and the cord comes out and it retracts normally, re-install the shroud and tank.
Posted on Oct 03, 2010
Key won't start my mower
starer is dirty take apart and clean dirt out of it reassemble star it
Sep 08, 2014 | Toro Recycler 22" 149cc Personal Pace Lawn...
Why my toro recycler 22in personal pace lawn mower wont start ?
I recommend that you call the store and get service under the warrenty.
Aug 06, 2014 | Toro Garden
How to change the pull reel
Just click on the link below and it will have videos that will show you how to change the pull reel. Good Luck and I hope this helps you out. : > )
How to replace a lawnmower pull cord - YouTube
Jul 24, 2014 | Toro Super Recycler 21" 159cc Personal...
How do I open the case around the pull cord on a Torro 22" recycler lawn mower?
It's been a while since I pulled one of those engines apart - the LV195 engines came in 2 versions. One has a detachable recoil starter that is held on by 2 screws, the other is an integral part of the cowling. Either way, the repair procedure is the same - remove the starter, or entire cowling as appropriate (may need to remove some plastic and the tank first), remove label on top, SUPPORT THE ASSEMBLY ON A DEEP WELL SOCKET or similar and drift out the central roll-pin into the centre of the socket drive the pin from outside to inside. If you don't support it, it WILL bend and make it useless. Make a note of the order of the washers and springs etc, then fit a repair kit.
May 03, 2014 | Toro Recycler 22" 149cc Personal Pace Lawn...
Remove carburetor
go to u tube and see if will show u
Oct 10, 2013 | Garden
Toro gts 6.75
you will probably need to replace the tabs that pop and grab the fywheel, the springs should be replaced as well.
Jun 15, 2013 | Garden
My Toro Personal Pace 22"
pull your spark plug and see if it will pull then, if so then it is hydro locked with fuel which can be caused y a bad fuel cap, not venting or a stuck open needle in carb causing gas to flood cylinder
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
Change oil in TORO GTS personal pace
warm engine remove dipstick place drain pan on floor tip mower on side so dipstick tube is over pan
Aug 14, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,076 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
