Question about Hitachi 50GX30B 50". Rear Projection Television
Broken screen I have a Hitachi Manufactured May 2001 that has a broken screen. Something was thrown at it by my 5 yr old and now there's a large spider web crack through the screen but the picture works fine. Is there any way to replace this screen and how?
  • Hitachi Master
  • 8,617 Answers
Yes, you can get a replacement screen assembly at the following link. they are used but in excellent condition. Just leave them an email they man the site 24 hrs a day so someone will get back to you quickly. Heres the link they will also explain how to replace the screen assembly which takes about fifteen minutes very easy job.
http://servicemanuals.vstore.ca/
Posted on May 26, 2008
Is it possible to fix an lcd tv screen that is cracked?
Hi Kristi,
I am sorry, a broken or cracked screen can not be repaired.
Aug 12, 2015 | Vizio Televison & Video
Screen broken-scissors thrown at screen-tv works but screen doesn't
Display might need replacement. It is better to show it to a qualified service technician.
Jul 17, 2012 | Vizio L37 Television
Plasma tv bad picture - something thrown at screen
Not worth fixing,if LCD,Plasma,DLP screen pannels is damage or broken only worth as salvage electronics boards parts.Because the tv corporations produced it limited LCD,Plasma or DLP screen pannels.They're the only one able to sell u the screen pannels,but they will sell it to u same as a new tv,might even cost more after the Plasma screen part is put in.Because of the labors.
Apr 26, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
Broken screen not cracked though object been thrown at the tv
Buy a new one,can't replaced the screen because the screen replacement about the same as a new one.
Nov 21, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Where do broken Toshiba's TV's end up?
HELLO
If your TV screen is broken then the only thing you can do is scrap it! To get a new tube installed will be expensive (much more than a new TV is worth).
Old TV's get recycled now and NOT re-sold.
Time to get a new TV!
Oct 09, 2009 | Toshiba 27AF42 27" TV
Broken screen
i have a 42"pd6600 which has a broken pcb board, my house insurance got me a new samsung 1080p and left me with the hitachi also. the set still works but flicks from picture to dark due to the pcb which aparently costs more than £400. would you like to buy it?
Aug 04, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi 53fdx01b top-left corner is now duplicating picture
tv has double image color red and a curl line on left upper corner also sometime in middle of tv it has line
Jun 01, 2008 | Hitachi 43FDX01B TV
Hitachi 50DX10B Power issue
Rollo, broken solder connections either in low voltage or sweep section of the board, probably in the horizontal out put area but could be anywhere. If you want to attempt the fix the board has to come out and you`ll need a bright light as well as a good magnifying glass to find the broken joints and then re-solder them, Be certain your tv`s AC cord is removed from the wall outlet before doing any soldering, good luck, BMW Rider
Dec 13, 2007 | Hitachi 50DX20B 50" Rear Projection...
Whirlpool Duet won't start
Open the door and look at the latch on the right side of the opening. Just above the hole the door latch fits into is a small switch. It should be sticking out about a quarter of an inch. You should be able to push it in and out easily. It is very common for these to break. If it is broken, the door latch assy will have to be replaced. About $65 for the part. You may be able to break a round toothpick or something else about that size to use as an actuator until you can get it repaired. Just stick it into the broken switch with about quarter inch sticking out. Then carefully close door. Post back to let me know if this helps or not.
Oct 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hitachi 50GX30B 50". Rear Projection Television Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
