Question about Peg Perego John Deere Gator HPX Ride on Toy
How to replace the motors - Peg Perego John Deere Gator HPX Ride on Toy
-Take the two screws out located beside the back of the seat.
-Pull the two plastic bars out of the back (that go up to be the rack)
-push the two black tabs in UNDER the rear fairings (they are hard to find but they are actually a round pipe that has a cut-out of it acting as a tab) push them in and it will pop right apart.
-on one wheel remove the black cap in the centre of the rim.
-grab a hammer and give the axle a good whack. Enough to get the safety tab to move off the end of the axle.
-pull the axle out and remove the three screen that are right behind where the wheel was.
Thats it!
-three more screws on the gear box will allow you to replace the motor.
http://www.shopjandl.com/sagi9993.html
Posted on Oct 03, 2010
  • funbobbybaby Jan 27, 2014
    If it only works in one gear its the switch not the motor
How to replace the blower motor resistor
David, Check the attached links,instruction and guides on replacing blower motor resistor. you can also google search your make and model# blower motor resistor replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to replace Blower Motor Resistor
How to replace blower motor resistor in Chevrolet Silverado
https://www.automd.com/633/how-to-replace-a-blower-motor-resistor
the blower motor resistor replace Google Search
Apr 30, 2016 | Cars & Trucks
Sorry its blower
Its faulty blower motor resistor. The low and medium speed on blower motor is controlled by resistor and its actual speed is high. So because resistor is not working, blower motors actual speed which is high is working.
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected. If it's faulty it has to be replaced.
For blower motor testing and replacing, check the link below: ----
Blower motor Testing/replacing for all vehicles?
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Dec 07, 2012 | 2006 Kia Sportage
Heater is not working
HEATER BLOWER MOTOR
These will help.
Thanks.
Nov 28, 2012 | 1988 Honda Accord 4 Door
Blower motor does not work, but getting voltage to motor & motor is good
It can be faulty blower motor relay or its issue with blower motor resistor.
Get the blower motor re-inspected. If its faulty it has to be replaced.
For blower motor testing and replacing, check the link below:----
These will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
2007 suzuki forenza wagon heater blower motor is not working
It can be faulty blower motor or faulty blower motor resistor. Get the blower motor inspected.If its faulty it has to be replaced.
For blower motor testing and replacing,check the link below:----
These will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
The motor for the heater is not working
HEATER BLOWER MOTOR
These will help.
Thanks.
How to replace a blower motor on a 2006 G6
For this replacement procedure,click this link below :---How to replace blower motor and blower motor resistor on Pontiac G6?http://technoanswers.blogspot.in/2012/02/how-to-replace-blower-motor-and-blower.html
---------Also more help solutions recommended.Click the link below :---Blower motor replacing for all vehicles?http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html----------This will help.Thanks.
Feb 01, 2012 | 2006 Pontiac G6
Blowing fuses on blower motor 2006 e250 econoline
Both are possible.But it can be blower motor issue mostly.Its taking too load and that's blowing the fuse.How to Test and Replace Blower motor on car? http://repairhelpcenter.blogspot.com/2011/12/how-to-test-and-replace-blower-motor-on.html--------- How to Replace Blower Motor Wheel? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-blower-motor-wheel.html
Also more help solutions recommended. Click the link below :---
Blower motor replacing for all vehicles? http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
----------Blower motor Resistor shorting problem? http://schematicsdiagram.blogspot.com/2011/12/blower-motor-resistor-shorting-problem.html
Jan 25, 2012 | 2006 Ford E-250
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
Jul 19, 2011 | Kenmore Ovens
I have a older m&s system central vac model av625 one motor quit the brushes are gone are parts available
You will need a new motor, not brushes, as the worn motor will tear through new brushes. Search online for the M&S motor replacement and you will see helpful sites that will provide the replacement motor. Replacing the motor is not difficult. Consider replacing both motors as the second motor will go out in the near future.
Jan 10, 2011 | M&S Systems Bagless Central Vacuum
Peg Perego John Deere Gator HPX Ride on Toy Logo
137 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
