Question about Farmall Tractor C ,super Av, Complete Gasket Set
Farmall super a rod and main bearing torque specs
What is the torque specification for rod bearings and main bearings
Main Bearing Bolts Torque Suzuki XL7 2.7 2003 - Fixya
www.fixya.com/.../t15635769-main_bearing_bolts_torque_suzuki_xl7_...
Jan 2, 2013 - Main Bearing Bolts Torque Suzuki XL7 2.7 2003 - Suzuki 2002 XL-7 ...What are the torque specs for cam caps on a 2005 Suzuki forenza 2.0 ... Need torque specs for 1.3 liter motor,connecting rod bearing and main bearings.
Oct 07, 2015 | 2005 Suzuki XL7 - Without speaker - Carpet...
What the torque specs. For a 2002chevys10 4.3vortex mains and rod bearing
Torque Specs Database
Type: Dim: Length: Head: Nut Grade: 20 Ft-Lbs 240 In-Lbs 27.12 N-m Connects: Connecting Rod To Engine Block Years: All Vote Record: Vote Note: Vortec - Rod Cap Nuts - 2 Steps: 20 FtLbs; +70degs
http://ww2.justanswer.com/uploads/ZZdaryl/2009-06-14_153454_torque.pdf
Main Bearing Cap Bolt 4.3L Step 1 15 ft lbs (20) Step 2 Additional 73 Degrees
i don't know if that's correct for main bearing caps since another link states it's much higher
4 3 Vortec Piston Specs eHow
hopefully a GM guy will chime in to confirm the main bearing torque
the rod bearing torques are the same on all the other links
Mar 25, 2015 | 2002 Chevrolet S-10
Torque specs,rod bearings,2003 nissan altima 2.5
I need the torque specs for the connecting rod and main be
Sep 10, 2011 | Nissan Altima Cars & Trucks
I need torque specs. for rod bearings and main bearings for 3.8L GM engine 1979 to 1981
FOR 1979 ROD BEARINGS TORQUE IS 40 FT LBS MAIN BEARINGS 100 FT LBS. FOR 1981 MODELS. ROD BEARINGS TORQUE IS 40 FT LBS. AND MAIN BEARINGS 100 FT LBS. CYLINDER HEAD BOLTS 80 FT LBS. CRANKSHAFT PULLEY BOLT 225 FT LBS. FAN PULLEY TO BALANCER 20 FT LBS.
Jun 02, 2011 | Buick Century Cars & Trucks
NEED TO KNOW WHAT ARE THE TORQUE SPEC N A F250 2001 GAS ENINGE FOR THE ROD BEARINGS AND MAINS BEARINGS 5.4
I hope this helps you. WF
  1. Install the main bearing cap bolts and the cross-mounted main bearing cap bolts.
  1. Tighten all of the main bearing cap bolts in two stages.
    Stage 1: Tighten the vertical fasteners 1 through 10 to 37-43 Nm (27-32 lb/ft). Rotate fasteners 1 through 10, 85-95 degrees.
    Stage 2: Tighten the cross-mounted fasteners 11 through 20 to 27-33 Nm (20-24 lb/ft). Rotate fasteners 11 through 20, 85-95 degrees.
Tighten the connecting rod bolts in two stages, using the sequence shown.
Stage 1: 40-45 Nm (30-33 lb/ft)
Stage 2: Rotate 90-120 degrees
Aug 21, 2010 | 2001 Ford F250 Super Duty Super Cab
Torque specs for 1.5 kia rio connecting rod
TORQUE SPECIFICATIONS kia rio
Cylinder Head Bolts:
(21.7ft.lb) or (3.0kgf.m) 90?
May 22, 2010 | 2001 Kia Rio
Need torque specs for 1999 Ford 3.0 rod & main bearings
ft lbs
Main Bearing Cap Bolts 75-85 56-62
Connecting Rod Cap Nuts 31-39 23-28
May 27, 2009 | 1999 Ford Taurus
Torque specs for 1998 tercel 1.5L
Main Bearing Cap Torque-42 Ft. Lbs.
Head Bolts Step 1-33 Ft. Lbs. Step 2- Additional 90 Degrees
Rod Bearing Nuts-29 Ft. Lbs.
Hope this helps
Apr 08, 2009 | 1998 Toyota Tercel
Main and rod bearing torque specs
do you have a Haynes Manual or Chilton? if not check your local library, they may have one, the specs are in there
Mar 31, 2009 | 1995 Ford F150 Styleside Regular Cab
Farmall Tractor C ,super Av, Complete Gasket Set Logo
505 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
