Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Random screen format adjustment!
For some reason the screen format on our tv keeps changing randomly while you're watching tv or a dvd. It doesn't matter if you set it to "smart" or one of the other settings, it has a mind of it's own and will just start to change and flicks about.
Any idea's what could be causing it?
  • Rolipayne May 26, 2008
    thankyou, where abouts would that sensor be.....?
Read the manual!!
Posted on Jun 05, 2008
I have a panasonic 42", the volume and channel was change on it's own. I needed a new DT board. It's the board with all the rca inputs. Cost for the part was $250 and labor was $300 with a $30 dollar charge for finding the problem. I ended up paying the $30 dollars and found the part online for $120. About fifty screws later the tv was like new! Hope this helps.
Posted on May 29, 2008
  • 52 Answers
Try blocking the sensor built into the front of the tv. If it cant sence light, it wont change.
Posted on May 26, 2008
Our movie keeps stopping for a couple minutes and starts back up. And keeps doing it so we can't watch our show.
That's pretty annoying. It would be helpful to know the specifics of the computer you are trying to watch the movie on; operating system, RAM...etc and how you are watching the movie; streaming, DVD, external drive...etc. The most common reason for buffering is lack of enough random access memory or RAM.
Jul 14, 2017 | Computers & Internet
My Fujitsu lifebook T902 keeps changing the screen brightness levels for no apparent reason.
I would think that if the virtual level controls are not changing, either the power socket/supply, back light or invertor has an issue.
Dec 01, 2013 | Fujitsu LifeBook Computers & Internet
How I can take off Random play from bus blaupunkt dvd-player. It shows (Random) on left side on screen when I put DVD in and movie jumps every few minutes. Very bad to watch movies, cause have to find...
There should be a DVD Repeat modes or "Repeat/Repeat Modes" button on your remote. Press that until it's back to "ALL" and it should play things properly again for you.
Aug 27, 2011 | Blaupunkt DVD-ME1 DVD/CD/MP3 PLAYER Car...
I have at 42in Plasma Samsung HPS4253. One day randomly my TV had red pixels all over the place. Anytime the screen goes ''black'' it is now red. When watching TV or movies any shadows or black sections on...
If the picture has red 'staining' all over the picture which is static then the fault is the Xsus pcb. If the picture has random 'sparklies' that change then it may be a case that either the ppower supply Vs voltage has deviated from its set voltage which can be adjusted by a potenitometer on the psu pcb...or if the psu voltages are correct (when compared to the screen label factory voltages) then by tweaking the Ysus trimmers, The fault could be a deviated tolerance on the Ysus.
Apr 23, 2010 | Televison & Video
Random flashing streaks on screen
Check multiple inputs and multiple sources. Check your dvd player; does it happen there? If not, you are probably right to suspect the cable box.
When you are checking multiple inputs, you want to make sure that if your cable box uses component or HDMI, that you check your DVD player on the same style input.
The reason for this is that your electrical chassis treats the analog (composite, s-video) inputs different from the HD and digital inputs (component, DVI, HDMI).
If you try your DVD player and cable box on the same input and experience the same probelm, you probably need to have the electrical chassis rebuilt in order to fix a problem on the tv's FMT board.
Cost: $800+
Wait time: 4-8 weeks.
Sep 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
How do I set the DVD picture to Full Screen as opposed to Wide Screen?
That is the way the DVD makers intended it to be. The TV cannot be adjusted to change that if it is a widescreen or "letterbox" movie.
Dec 12, 2007 | RCA TruFlat 27F520T 27" TV
Screen 1/2 black with random caption in middle side
CHANGE CAPTIONS SETTING YOU HAVE IT ON TEXT1 TURN OFF THIS SETTING. IN YOUR SETUP MENU
Aug 16, 2007 | Sanyo DS24205 24" TV
Black Screen
Ok, this is probably what has happened, you say that you have played games on your tv, well the thing is with HD and Plasma Screen tv's is that when you play Hi-Res games on them the games backdrop will burn itself into the screen, causing the screen to turn dark and not reveal the correct picture it should. People need to learn about this!!!!! Playing games on HD and Plasma tv's will screw up your resolution!!!
Jan 19, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
163 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
