Question about IBM Infoprint 1332 Laser Printer
Our IBM Infoprint 1332 has a message that says '202 Paper Jam Open Rear Door' and there is NO paper in there. How do we reset it?
4 Suggested Answers
SOURCE: IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Posted on Apr 17, 2009
SOURCE: 202 Paper Jam
A 202 error usually means that there is a problem with the fuser, more than likely the fuser exit sensor is jammed - either with a piece of paper, or the return spring on the sensor has stuck. Check this sensor, making sure it can return to the upright position freely. This should clear the problem. If it doesn't, or the sensor arm is broken, a new fuser should solve this problem
Posted on Jul 17, 2009
  • 26 Answers
SOURCE: I have infoprint 1125 that shows 202 paper jam, but no jam
Usually it is the white roller that is going bad in the tray. These are easy to replace - but fragile. They have a small clip that may break if you push it to hard. If you dont have a replacement - try cleaning them real well. If that doesnt work - you can take it off and remove the "tire" part and put it back on inside out. It fits funny but works if no parts are available.... All the rollers are the same for almost all printer like this.
Posted on Nov 30, 2009
Constant paper jams
Open the printer and with a blower clean it thoroughly.
This resolves the paper jam issue many times.
Nov 16, 2011 | IBM Infoprint 1332 Laser Printer
How many pages per minute on a InfoPrint 1332
The InfoPrint 1332 has a maximum output speed of 35 pages per minute. This speed can be less if you are using thicker paper or paper that's not 8.5" x 11", and other factors can affect the speed as well.
Apr 14, 2010 | IBM Infoprint 1332 Laser Printer
What is this ??
Typically there is a piece of paper caught in the fuser exit. If no paper evident(ie paper feeds cleanly, stops 1 inch past fuser) verify there are 2 sensor exit flags present and free to move. Occasionally 1 of the flags gets broken off the sensor causing this jam.
Jan 27, 2010 | IBM Infoprint 1332 Laser Printer
Keep getting an error message "202 Paper Jam Open Rear Door", cannot clear the message. We ordered a maintenace kit maybe 3 months ago.
If you can't see any paper stuck inside the printer when you open the rear door or when you remove the toner cartridge, the rear paper flag is either stuck or broken.
The flag is a small piece of plastic which sits at the rear of the fuser and as the paper exits the fuser it pushes the flag down. The easiest way to see this is to remove the rear door then the rear cover (two screws).
If it's broken you'll require a replacement fuser (i don't think you can get the part separtely), but if you have recently installed a maintenance kit, i would contact the supplier and ask for a replacement.
Apr 20, 2009 | IBM Infoprint 1352 Laser Printer
Paper jam
disconnect the power and usb cable from the back of the printer and press and hold down the power button for 30 sec and then reconnect the cables and try again...open the backdoor and try to move the rollers in upward direction.Make sure the unit is connected directly to the walljack.
Nov 28, 2008 | IBM Infoprint 1332 Laser Printer
I had this same problem.... I put a new toner cartridge in it and it worked fine.
Nov 07, 2008 | IBM Infoprint 1422 Laser Printer
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
202 Paper Jam
If you have a duplexer check in there. also sometimes the paper will get stuck in the fuser and will be torn off inside. you can take the fuser out with a phillips (2 screws) and and 2 plugs. check and rotate fuser by hand to be sure it is clean. re assemble
Aug 04, 2008 | IBM Infoprint 1120 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
IBM Infoprint 1332 Laser Printer Logo
358 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
