Question about Maytag MZD2766GES Side by Side Refrigerator
I have a Maytag Plus model MSD2456DEW, can you tell me what the normal settings for fridge/freezer should be for optimal storage?
  • Maytag Master
  • 43,501 Answers
For the fridge you want about 39F and for the freezer you want to be a 0F or below...
heatman101
Posted on Oct 02, 2010
The refrigerator is not running cold.
most fridges are operating best at +(plus) ,-(minus)3.5 degrees C, at what setting do you have it currently? (settinngs can be between 1(one) up to 10(ten) depends on model and make). most people realize that the fridge is not cold and set the settings(fridge control) up, that is wrong, try to keep freezer build-up clean and run the fridge on a setting of 1(one). switch of the mains, clean the fridge and follow above instructions. if the problem still exists after that then you need to replace the gas
Dec 12, 2010 | Maytag MTB1954ME Top Freezer Refrigerator
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Feb 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
Maytag MSD2454GR
Im going to be honest with you,to me it sounds like 1 of 2 problems,
either you need a re gas on your fridge or you need a compressor.
Let a repair man take a look for you just to tell you what it is..
Sorry for this news.
Wouter.
Sep 30, 2008 | Refrigerators
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Maytag ice20
When replaceing the highvoltage control board be careful to not handle it too much as nano voltages can burn it. Unplug before repair. Simply hook it up the way you unhooked it very easy and in the left back of the fridge. Now that it's installed plug fridge in and push back to wall. Look at model tag and write down your code something like 0304 most likely. Go to digital control hold down door alarm and freezer - minus button for 3sec. then let off door alarm now you should see PE flashing the fridge wants personality code (the one you have wrote down). Let off minus now it should show 0000 now push minus once more a decimal should show up 0.000 the decimal indicates what number your about to change. Move the decimal with freezer plus button and lower or higher number setting with fridge side buttons.Once your done hold down freezer minus till the numbers are flashing then open any door and close. Now the fridge should be working properly.Hope I helped
Dec 12, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Sep 03, 2006 | Maytag MZD2768G Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
101 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
