Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
How to remove and replace the washer lid switch on a whirlpool model LTG6234DQ1?
ghappliances
  • 126 Answers
SOURCE: replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
AlmostBob
  • 550 Answers
SOURCE: I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Posted on Oct 02, 2008
  • 1122 Answers
SOURCE: defective lid switch
you can bypass the lid switch,remove thw 2 screws on the console one on each side,flip the console up,you will see a 3 wire jack in the middle on the washer,disconnect the jack,the wires going to the console clip the 2 outside wires leave the green and wire nut the others together,plup back in and your done,let me know how you do-mike
Posted on Oct 26, 2008
scottowa
  • 87 Answers
SOURCE: how do I get to the lid switch to replace it on my washer
Pull of the end caps #14 & 11 on the diagram. Remove the screws and the front panel will flip up. Then there are 2 clips connecting the bac to the cabimet. Snap those out and the the WHOLE front of the machine comes off if you tilt it forward. Go to sears.com and parts to bring up any model for anything and you can kind of see how things go together. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11022852100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00002&componentDescription=CONTROL%20PANEL&documentId=P0103381&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jan 23, 2009
  • 1122 Answers
SOURCE: how to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Posted on Apr 20, 2009
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Estate by whirlpool model SM8280867. Filled, then stopped. What's wrong?
Charla, By what you have stated, it sounds like a lid switch failure. I recommend checking the screws for the lid hinge first.The lid has to be closed for the motor to run in the washer. If the lid switch is faulty, it will act as if the lid is open. A quick check you can do is to run a cycle with the lid switch jumped. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console.Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and white wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Then start the washer in a cycle, and let it go. If the washer completes the cycle, you need to replace the lid switch. Remove the jumper and order the part. The jumper is only of the test do not continue to operate after test.
Whirlpool Appliance Parts
Whirlpool Appliance Parts Whirlpool Appliance Parts from Easy Appliance...
http://www.repairclinic.com/Shop-For-Parts/a11b5/Whirlpool-Washing-Machine-Parts
Mar 05, 2016 | Whirlpool Washing Machines
Top loading lid switch does not work. hitting the lid (when closed) will start cycle. How do you access this switch for replacement?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Feb 12, 2011 | Washing Machines
When lid is closed,the switch is broken and washer won't start.how do i raise top of washer to replace swich??
Jan 16, 2011 | Washing Machines
Want to replace the spin cycle switch that is activated when the top lid is closed. How do I get at the switch? Thanks.
Dec 10, 2010 | Kenmore Washing Machines
My kenmore ultra fabric care heavy duty 80 series model 110 will not drain. The problem occured after a heavy load knocked the lid switch off during the spin cycle. How do i fix this/replace the lid...
Nov 05, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 70 series #11020722990 how to open cabinet and replace lid switch?
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Aug 10, 2010 | Kenmore Washing Machines
Have to trip washer lid safety switch with something more substantial than little 'plunger' attached to the washer lid to get washer to drain and spin during rinse cycle. do i need to replace the safety...
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet to replace it.
It comes as a complete unit and you can't replace just the plunger.
May 03, 2010 | Kenmore 23812 Top Load Washer
Whirlpool ThinTwin LTG6234DQ1
CHECK YOUR LID SWITCH IT HAS PROBABLY CAME LOOSE OR IS OUT. YOU CAN USE A OHM METER TO CHECK IT OR UOY CAN JUMP THE WIRES WITH A TEST LEAD
Feb 27, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
